Page 2 of 2 FirstFirst 12
Results 21 to 31 of 31
Thread: Car Eats alternators!!! HELP
  1. #21
    Camal Clutch
    Aug 2008
    South Hills
    80
    Quote Originally Posted by RUTHLESS View Post
    Not to get off topic but tell you buddy to install a high output alt and a second battery in the trunk with a charge relay setup. The CAP is just going to brandaid the lights dimming because it buffers the spikes but the system will keep cooking factory alts because the caps adds a load to the total draw of the system. I was running 3 deep cycles with a 230amp alt connected with 0gauge wire. My lights didnt blink but I could cook food on the alt when I was screwing around at shows. Dont even ask how much power I was pushing because it was down right stupid.
    Just trying to save that guy some cash and trouble in the long run.
    You beat me to it!
    The biggest problem with installing a system is, most people run big ass power wires but never upgrade anything else. You can't expect a system to work properly if you have a 4 ga or 0 ga power wire but an 8 ga ground... I usually suggest that all grounds must be upgraded (batt to block, block to chassis, chassis to body) and the alt to batt +.
  2. #22
    Senior Member ttk53's Avatar
    Sep 2008
    369
    Quote Originally Posted by Zakerid View Post
    I like this procedure but usually use a test light (easier to see when working alone.
    When testing for shorts my quick and easy way is to do the following.
    -Pull the + cable
    -Connect testlight between cable and battery (if the light is lit = you have a short)
    - disconnect 1 circuit (start with fuses) at a time, if the light goes out you have found the circuit in question. If light stays lit, reconnect circuit (fuse, relay, ect) and continue disconnecting circuits.
    Last time I had to do this, I went through the entire fuse box without success. The culprit was a fan relay in the engine bay.
    Good luck.
    ok i did this and it is the #7 seven fuse for my dome light wtf?
  3. #23
    Camal Clutch
    Aug 2008
    South Hills
    80
    well... was your dome light on?
  4. #24
    pa
    860
    Quote Originally Posted by ttk53 View Post
    Door switch maybe bad..
  5. #25
    Sep 2008
    369
    Quote Originally Posted by ddmi-twin90gt View Post
    only does it when door is open light stays on with key on. This isnt what is wrong my battery holds a charge fine.
  6. #26
    2,145
    Power seats, cig lighter, power mirrors I think they are all on that fuse but I would need to look.
    Pull your shifter cover and see if anyone spliced gauges into your wiring at one time and left I wire bouncing around. Everyone likes to play with those wires.
    The funny part is that I would think the fuse would have blown if it was a heavy draw.
    Stock 03 Cobra Vroom Vroom!!
  7. #27
    Sep 2008
    369
    check this in my dd does the same damn thing I think it may have been my BAP wire going to rerun it with a fuse this time! waiting for another alt.
    but have a 4# lower and long tubes to put on! Can this littel Eaton make 560whp? We will find out.
  8. #28
    Senior Member 32valve's Avatar
    earth
    154
    Thanks I'll pass on the info..............
    66 Fairlane GTA 390
    2011 f150
    08 SHELBY GT500 (sold)
    04 COBRA (sold)
  9. #29
    Sep 2008
    369
    Couldn't get lower pulley off and still have to run a new BAP wire but will update if i find out whats wrong!
  10. #30
    Sep 2008
    369
    New Battery
    New BAP Wire
    4# Lower
    3.2" Alt Pulley
    New Alternator
    Alternator is already whining and Im not going to drive it and blow it up. Open to any ideas.
  11. #31
    Sep 2008
    369
    my newest alternator
    1: Start the car, charges fine, for a little then once warm will drop voltage to like 13.5 try to drive it and the batt light goes on and off.
    now
    there is a plug right by the battery under the fuse box that the LG/R wire goes into. If I unplug this the voltage instanly jumps to 14.4 and I can drive the car and everything is perfect.
    Well other than that plug prevents the batt light from coiming on if it does stop charging and make the oil pressure gauge stop working.
    so I know that the green wire is from the ignition and allows the alternator to turn on and off. but what could be wrong that it is cause the alt. to fail.
    thanks and sorry for my ramble
    Tony
  1. Terminator Alternators
    By ttk53 in forum Ford Vehicles
    Last Post: 08-01-2011, 11:09 AM
  2. F.S. carb, 2 tires, and 2 alternators
    By crazylou in forum Ford Vehicles
    Last Post: 03-28-2011, 02:56 AM
  3. Replies: 0
    Last Post: 08-13-2009, 04:42 PM
  4. 100 bucks to anyone who eats one of these
    By FineLineMtrSprt in forum Pictures & Videos
    Last Post: 01-21-2009, 08:22 PM
  5. BMW eats a deer
    By Silverhatch in forum Pictures & Videos
    Last Post: 02-02-2008, 02:26 PM
