Results 1 to 4 of 4
Thread: 5spd from a 4banger?
    ruffsdale
    3,625
    heres my question. i plan on running my 351w in the fox till my other drivetrain is ready... would the 5 speed hold it? bellhousing the same or no?
    2013 Mustang Gt GHIG
    1978 F150 Camper Special
    1999 Harley softail
    1998 Buell Thunderbolt
    1997 Buell Thunderbolt
    Senior Member oldfox's Avatar
    May 2009
    296
    The 4 cylinder transmission will bolt up to a V-8 bell housing but you will need a different pilot bearing. The 4 cylinder transmission has a smaller diameter input shaft where it fits in the pilot bearing.
    How long it will last is up to you and your driving habits. Just remember that the transmission was built to take the power of a small engine. It will be the weak link of the drive line. If you don't put it under the pressure and power of the V-8 engine it will last a long time. If you push it you brake it. I'm putting a V-8 in my 4 cylinder fox and I'm going to run the smaller transmission to get by until I find a better heavy duty trans.
    Mt Pleasant
    2,916
    ive seen 4 banger trannys hold up better than v8 trannys...hit or miss
    Greensburg
    843
    The 87-88 TurboCoupe, and 90's 4 cyl fox stang transmitions ARE the world class ones. They just got a deeper first gear ratio (3.97), and the input shaft is smaller. No difference, one is not stronger than the other!! the 4 bell housing to trans bolts are the same as well, so no adapter is needed there. The pilot bearing can be used out of a festiva (1989?) or (?)ranger(?) for the input shaft to work in the v8 motor. Dan, what year 4 cyl car is this coming out of?
    -Frank-
    1986 GT-- HCI
    2011 WRX
    1999 B2500 7.5/9 drop
  1. 93 lx hatchback 4banger
    Last Post: 01-20-2011, 08:54 AM
  2. 94 Mustang GT 5spd
    By cobradru in forum Ford Vehicles
    Last Post: 08-02-2010, 08:43 PM
  3. 1988 LX 5.0 5spd
    Last Post: 06-03-2009, 08:35 AM
  4. 93 5.0 5spd conv lx
    Last Post: 01-04-2009, 03:59 PM
  5. parting out 89 Lx 5.0/5spd
    Last Post: 10-23-2007, 07:10 PM
