Results 1 to 20 of 22
Thread: Vortech setups?
    Senior Member Ares's Avatar
    Pittsburgh, PA
    2,363
    Vortech setups?
    So I have this crazy thought of a Vortech V-1 S trim and was wondering who has used this setup. Complete non intercooled kit. Could piece together an air to air setup as I know intercooled would be better.
    Only thinking of about 8psi.....for now
    Not sure if the cams I am using would work well. Hitecth Stg2 NA .550/.500, 234/230@.050 111LSA. The stg2's for a centri blower are same spec except being 112LSA. Not sure if lobe profiles are the same. Course the stockers could go back in till I could get proper ones.
    Sanity may pull me back but then again. This is somethig I have wanted to do for few years now.
    Ed...
    2012 Ram 2500 4x4, 5.7 Hemi, leveled, 35" tires
    2004 Mustang GT - Comp Orange/5speed Best 1/4 11.94@113.64, 1/8 7.59@89.48, 1.57 60' - Best 60' 1.51, just a NA 2v
    that lsa of 111 is way better than the stock cam lsa of 108(i think), but those would not be bad cams at all..
    Pittsburgh, PA
    2,363
    So far found the V1 S trim setup complete for $2899 new and my finger is slowly pulling on the trigger
    Looking at the IceVex air to air coolers
    http://www.icevex.com/products_35vap.html or http://www.icevex.com/products_351090x.html
    or
    Air to Water setup from Frozen Boost http://www.frozenboost.com/ which I would be more inclined to try. Plus the setups they have look easier on the wallet.
    Ed...
    Polar Vortex
    6,031
    Quote Originally Posted by Ares View Post
    or
    If I did it again I would have bought the tuner kit and saved hundreds over the regular kit. Just something to think about. You're probably not going to run an fmu and going to get a custom dyno tune, so why waste the money on the tune from vortech or the fmu..
    Pittsburgh, PA
    2,363
    I can get the tuner kit at $2549.00 but then need injectors and fuel pump. Pretty sure MAF and I would get it tuned myself anyways.
    Complete kit has the 38lb injectors and new fuel pump.
    Ed...
    Polar Vortex
    6,031
    Whats the price diff. between the tuner kit and the complete kit?
    Pittsburgh, PA
    2,363
    Quote Originally Posted by John4cam View Post
    $350.
    Talked to the company and they said they are 38lb Lucas injectors and Vortechs 255lph "small" in tank pump for 98-04 Mustang/Cobras. Injectors seperate are $339, Fuel Pump $194, Total $533 if added to Tuner kit
    Those should work fine for what I want. 38lb injectors should support up to 506hp at 100% duty cycle
    Ed...
    Polar Vortex
    6,031
    $350.
    Sounds like a good deal then.
    Modular Ford Performance Wolfpack Speed's Avatar
    Pittsburgh, PA
    4,321
    The complete Vortech kits are fine but they are designed for a bone stock car. The hardware that comes with the complete kits becomes a limiting factor real quick, even on a stock motored car. If you think you would ever turn the wick up on a built motor, you would be better off getting the tuner kit. With a modified car you need a bigger MAF, you could do a cobra/lightning 90mm meter and always add a mafia if you need more range at some point. I would just get the sct ba2600 and be done with it. The injectors that come with the kit are fine but once again, wouldn't be enough if you turned up the boost, I would get 60's. The fuel pump that comes with the 99-04 kits is a focus pump, it is pretty much maxed right out of the box. On a modified 2v that thing will be maxed but you could always add a small amp bap, oem cobra fuel system would be a much better choice.
    Mike
    Wolfpack Speed, Inc.
    4290 Campbells Run Rd
    Pittsburgh, PA 15205
    (412) 279-4902
    Pittsburgh, PA
    2,363
    Mike that was something I was thinking about at work today. So I ended up ordering a V-2 SQ S-Trim tuner kit. Was same price as the V-1 S-Trim tuner kit so went with something slighty newer in design. Can always send it out down the road for the newer SC or SCi upgrade when needed. I wasn't liking the new V-3 self contained unit's. Rather have oil moving and not sitting cooking.
    I have looked at the SCT meters and also the Abaco DBX meters. http://www.abacoperformance.com/products.htm
    Fuel pump I would like to use my stock GT tank. Do Cobra pumps work with a GT tank? I'm open to input that will be reliable. Still looking at injectors and brands. Probably will upgrade fuel rails. I know I need to dump the Steeda balancer.
    Thanks guys for adding your thoughts to this and to anyone else that like point me in a good reliable setup.
    Ed...
    Polar Vortex
    6,031
    There's always great deals on low miles 42#'s on svtp, and the corral almost daily.
    Edit: Or as mike suggests, there are always 60's as well...but a little more money it seems.
    Pittsburgh, PA
    4,321
    I hear you on the self contained stuff, I have never been a fan my self with all the durability issues that procharger has had over the years. What I will say is that I have installed several self contained Vortech units and have yet to have a problem. I have no knowledge or experience with the abaco meters, not saying they are bad but I like to stick with what works! I believe you can run a cobra fuel system in a gt tank but I believe they have issues with running dry, just get the cobra tank and be done with it. You can by mine if you want, may be for sale sooner then later! Stick with known injectors with good data, stay away from off the wall models just to save a few bucks.
    Good luck either way!
    Mike
    (412) 279-4902
    never stock biminiLX's Avatar
    Beaver
    2,406
    or
    Once you go boosted you'll never go back Ed
    Thanks for posting the intercooler stuff, I have a 4" supposed to be 1000hp IceVex intercooler and never new they had a site or anything.
    Good luck, J
    '91 LX Bimini Blue
    427"/88mm on 16psi
    '99 Contour SVT
    Clean DD
    Quote Originally Posted by Wolfpack Speed View Post
    Stick with known injectors with good data, stay away from off the wall models.
    Mike
    Hmmm, I think I have heard this one before....
    HAHAHHA
    Pittsburgh, PA
    2,363
    Gah feel like I been waiting forever. Just waiting on Vortech to ship this out today or monday. Was held up waiting for batch of parts to come back from machining. Hoping that since they stopped with S-trims that this comes with the newer SI impeller instead.
    Won't be relaxed untill I see that big brown truck drop this off at work.
    Ed...
    Polar Vortex
    6,031
    Nice, gotta post a few pics when you get/install it.
    Senior Member Jivepepper's Avatar
    Morgantown WV.
    563
    I have been running a vortech set up almost 6 years. Very relible, 5 years with a V1 s-trim then a T-trim. Go with the tuner kit and add your own support mods.
    665/540 New times coming
    Old times with 516/453 11.10 @129 Best trap 130.69 -750' DA lol
    DYNO VID ---> http://www.youtube.com/watch?v=K9uOS732mdA
    Pittsburgh, PA
    4,321
    Who did you buy your kit from? Vortech is very quick with turn around time. I ordered an srt8 6.1 challenger system last Friday, those kits are built to order and ups tracking says it will be here tomorrow....
    (412) 279-4902
    Pittsburgh, PA
    2,363
    Superchargersonline.com, Be first and last time I buy from them. Hell I'd been happy to have gone to Summit and paid an extra $141.01 at this point. I looked at my order history and it shows "Filled", use to say awaiting shipment and "Paid in Full" yet my money is still in account. Did say authorized for payment.
    They have till well, tommorrow to supply tracking info and prove it has been shipped or this order is cancelled. I almost called Vortech today just to see if they anything in their system to ship to me. Which I may still do.
    Try to save a few dollars and get F'd anyways.
    Ed...
    Morgantown WV.
    563
    Summit will price match
  1. Changing setups
    By Silverhatch in forum Pictures & Videos
    Last Post: 08-14-2013, 08:25 PM
  2. Replies: 1
    Last Post: 04-25-2011, 07:22 AM
  3. auto setups
    By crazylou in forum General Tech
    Last Post: 04-03-2010, 05:15 AM
  4. foxbody big/little setups
    By scott5 in forum Fox-SN95
    Last Post: 03-23-2010, 08:52 PM
  5. TV setups
    By scott5 in forum The Bar
    Last Post: 01-07-2009, 09:53 PM
