Page 3 of 4 FirstFirst 1234 LastLast
Results 41 to 60 of 71
Thread: Project bigblock fox
  1. #41
    trick flows might be i nthe price range for it.. im still debating what pistons an rods i want i wanna get my shortblock built first
    Don't build the shortblock until you know what heads you're going with. Some heads require the pistons to be notched in a much different spot.
    Don't put the cart before the horse.
  2. #42
    Bent but not broken. 03SnakePlissken's Avatar
    Beaver County
    249
    Inkdcountryboy said he didn't want to spend the coin on a set of $1700 SCJ's. I really don't think he'll be considering EX514 or similar.
    He also said this engine will be 460ci, not 521-600.
    Remember this is a low-buck pump gas street car that will (*I'm assuming*) get a solid flat tappet cam.
    I used a Cam Reasearch Corp solid flat in a 466 and had great results it was on ported DOV-E heads with port plates and flat tops (cheap TRW's) and made 394 at the wheels through a C6/NP-205/Dana 80. I would guess it was 550-575 crank HP or so and it was a pump gas build. With the heavy truck trans/transfer case/rear end, your expecting about a 30-35% loss.
    We were very happy with how the power came on early and yet would allow us to run 6500-7000 RPM down the track.
    That had Manley steel H-beams and a OEM 460 crank in a 2 bolt block. It never came apart, it was eventually pulled and put in the garage where it has been resting for maybe 7-8 years now. Soon it will be placed under the hood of a 86 T-Bird or a 84 Camaro. The camaro with a 460 would really be kind of neat.
    2003 Terminator Vert - Silver Metalic Number 2763 of 5082
    The usual bolt ons, almost bone ass stock!
    Buy Your Amsoil Synthetic Oil now!
    Click here to become a prefered customer NOW!
  3. #43
    Quote Originally Posted by 03SnakePlissken View Post
    I used a Cam Reasearch Corp solid flat in a 466 and had great results it was on ported DOV-E heads with port plates and flat tops (cheap TRW's) and made 394 at the wheels through a C6/NP-205/Dana 80. .
    Now that sounds like an excellent street build.
    Low buck and good power....
    Edit: Although with flat tops and small chamber heads that sounds like something that could've needed race fuel. Did you run pump on it? With a true flat top (except for valve relief) @ 0 deck, .040 gasket and 73cc heads, that's above pump gas compression ratio.
  4. #44
    Beaver County
    249
    It was intended for Sunoco Ultra with a bottle of 104+. That is how it ran most of the time because the rules we were sled pulling with said no race fuels allowed, and you could not hide the majical scent of VP/Cam2/Turbo-Blue!
    I did not push the timing out as far with the pump gas, I ran it locked at 36 degrees. On VP C-14 I would set the timing out at 38 degrees. It actually made 8 more HP at 38 degrees on the chassis dyno.... but on the pump gas it did not like it.
    It was a true 0 deck flat top with DOVE heads, the pistons were cut for the cam, if my memory serves me correct it was a 0.620" cam.
    The combustion chamber was smoothed and polished. No sharp edges were left. Used Childs and Albert gapless rings. I had Manley stainless valves back then, nothing exotic.
    It also had a 4150 750 HP-Pro series that I had holley custom shop add a 850 throttle body base plate to and custom machine the 750 lower main body to connect the ports. Yea, I cheated a bit. I still have that carb I believe. It was a monster.
    We ran that on the dyno with a port matched Wiend Stelth SCJ intake. Later (and not dyno'ed) I changed to a Victor with a Dominator. It REALLY liked the intake and carb swap. Massive change in the way it pulled down the track.
  5. #45
    Ya..I ran the numbers and you were around 11.85:1 on a flat tappet cammed iron-headed deal which is certainly too high unless there's no timing in it.
    Still sounds like a nice setup to "stay within the rules.". :)
  6. #46
    Beaver County
    249
    Did you ever see Scott Johnstons little wedge head V-Cut thing he does? Scott's site is reincarnation automotive or something real similar. He claimed that allowed him increase CR on lower octane fuels. I never tried that, but the concept of a more violent quench makes sense.
  7. #47
    Beaver County
    249
    I'll look for my little build notes tonight or tomorow night and verify, but for some reason I remember that engine being around 10.5 as planned.
  8. #48
    ruffsdale
    3,625
    well my crank turned out to be headed to the scrap pile.. so im gonna stroke and poke it..i gotta figure out what kinda cubes i can get with only going .30 over id go .60 but thats probably pushing it for a streey motor. i ordered my 31spline mosers tonight. so now all i need is a set of 3:73 and a bearing and seal kit. to get the rearend mostly together other than my c-clip elim's and my heavy duty cover!
    2013 Mustang Gt GHIG
    1978 F150 Camper Special
    1999 Harley softail
    1998 Buell Thunderbolt
    1997 Buell Thunderbolt
  9. #49
    Beaver County
    249
    Check with Mark Petros at Greensburg Machine and Driveline for your gears and such. He usually beats Randy's and all the big sites, and he really knows his chit. He can ship to you also, or install for you if desired.
  10. #50
    ruffsdale
    3,625
    thanks but ill probably just get a set of ford gears off here an i setup my own rear's pretty simple process dont need a degree in rearend technology lol
    1999 Harley softail
  11. #51
    ruffsdale
    3,625
    Got the rearend in primer. waiting for the spool n axles to get here now..and gotta hook up with someone an get 3:73s this weekend ill probably order my bearing and seals by friday.. still waiting to hear about a set of axles braces.. might buy that kit for $179 off ebay with the Rear cover.... i linked it under general tech and no one had a response to it good nor bad... so still gotta figure that out.
    1999 Harley softail
  12. #52
    I got a nice internal balance 429 crank and 429 rods if you're interested. (cheap!)
    You have a cam picked out yet? I got a buddy selling an Edelbrock performer rpm with matching lifters he'll sell real cheap as well. It's a hydraulic flat tappet (no maintenance). Would be a nice street/strip cam for something in the 429-472" range.
    Sorry though....no 3.73's. Which would be a good gear for your combo if running a 26" tire.
  13. #53
    ruffsdale
    3,625
    ill keep your crank/rods in mind..im thinking of doing a stroker kit for it. havnt decided waiting till the cars done before i play with the motor lol
    1999 Harley softail
  14. #54
    ruffsdale
    3,625
    once the rears done my next choice is gonna be team z rear suspension kit #1 or #2 off the site...once i get that in i can assemble the back end!!!!! wohoo lol
    1999 Harley softail
  15. #55
    ruffsdale
    3,625
    Spool and axles arrived today..so now onto buying the rest of the parts needed to finish this here job...but heres a couple pics of the rear i got it in primer till the braces are on then ill paint it all
    1999 Harley softail
  16. #56
    Strip series 1 is what me and mike(wolfpack) are going with. it may be alil more that what you will need for the goal that you have. But that #2 is a great setup also
  17. #57
    When you dropping your car off Scott? (Or is it already there?)
  18. #58
    ruffsdale
    3,625
    just got home from a trip to lmm..got my 8.8 rebuild kit and a rearend girdle.. im gonna put the center section together this weekend..
    1999 Harley softail
  19. #59
    Not yet.. I decided im going to use another body (00) instead of my 95 so i have to do a few more things to it before it can go.. Should be going sometime this winter.
    What girdle you go with?
  20. #60
    ruffsdale
    3,625
    i got a Mac... and i think im also gonna go with the strip series 1 also for my rear suspension... all i gotta find to finish this 8.8 project is a deal on c-clip elim's.. and a a disc brake setup off a 94-98 v6 car for the rear!
    1999 Harley softail
  1. Fox body project
    By Rej082 in forum Ford Vehicles
    Last Post: 01-23-2015, 05:52 PM
  2. 88 fox vert. project sale or trade
    By matty g in forum Ford Vehicles
    Last Post: 07-09-2012, 11:26 AM
  3. Project....budget box of fox
    By Erics89GT in forum Pictures & Videos
    Last Post: 03-09-2012, 01:52 PM
  4. new project fox body
    By PSPstang in forum Pictures & Videos
    Last Post: 04-18-2010, 09:36 PM
  5. cheap fox project
    By J-rod in forum Ford Vehicles
    Last Post: 01-13-2008, 01:27 PM
