Results 1 to 6 of 6
Thread: To many miles?
    Yellow is faster!
    York PA
    273
    To many miles?
    Hey guys,
    Due to limited funds, my plans for the 87 are changing as I would like to get the car back on the road. Considering a GT40 headed exploder engine. That I will convert to carb and put a nice cam with good valvetrain. Now onto the issue.
    Hypothetical for you to consider:
    How many miles are to many? IE when normally would you need to bore.
    I know the easiest and simpliest way will be to pull the cylinder heads and check the tolerances on the bores. Well I highly doubt a junk yard will let me do this prior to purchasing a motor. And I also know that lower the better (all depending on how well the motor was cared for).
    I am asking this because my stock block out of the car needs bored and I don't have the cash right now to have it done.
    Thanks
    I'd personally try to stay under 75K for a used shortblock.
    Yellow is faster!
    York PA
    273
    Thanks Paul!
    You gonna have your beast out and about this year?
    Quote Originally Posted by 04yellowcobra View Post
    Hey guys,
    Thanks
    It really "depends". There are so many variables that contribute to wear and mechanical failures. I've seen 5-Liter longblocks with an excess of 150,000 miles and then again I've seen 60,000-70,000 mile engines that are oil burners. The 1993's hypereutectic design's high silicon content and lower coefficient of thermal expansion allows these pistons to be fitted with tighter-than-usual-piston-to-skirt-to-wall clearances. The close fit provides a more stable ring platform, to improve sealing and oil control.
    Trying to locate a 1993 and newer 5-Liter engine aside from the fact that it is newer, may be a better choice.
    LowHill
    2,679
    I agree, It would be nice to find one thats still in the car so you can see the mileage on it rather than taking someones word.
    Yellow is faster!
    York PA
    273
    How about a 351 with less than 100k?
  1. Wrecked w/ 12 miles on it?
    By Dan B. in forum The Bar
    Last Post: 12-07-2014, 05:23 PM
  2. 83 Mustang GT 5k miles
    By Monkeygrits in forum The Bar
    Last Post: 07-13-2012, 11:06 PM
  3. too many miles?
    Last Post: 06-09-2009, 08:30 PM
  4. 0 miles to empty
    By blackfive-o in forum The Bar
    Last Post: 05-03-2008, 09:39 PM
  5. 15, yes 15 original miles on 87 GN
    Last Post: 02-23-2008, 09:58 PM
