Results 1 to 8 of 8
Thread: Nice Track Outting
    Senior Member Ares's Avatar
    Pittsburgh, PA
    2,363
    Nice Track Outting
    Spent wednesday TnT and saterday race trying to dial in my shift points. Which I couldn't do before easily without knowing where car is making it's power. Left it the same as wednesday for first time run.
    Car goes 12.527@109.46, 7.996@83.55, 1.662 short. Still missing thru top half of track.
    For next run I pulled 2* total timing from 4-7K, tried adding 2% fuel at 2-4k, added 4* intial timing. Set my shift points to 6400 1-2, 6350 2-3 and 6300 3-4. Launch at 6000 and 14psi in slicks.
    Car goes 12.385@110.35, 7.900@83.55, 1.656 short. Still missing top half of track.
    1st round elims
    Car goes 12.384@106.58(tapped brakes at strip), 7.897@86.74, 1.661 short. Car would have been about 12.378 looking at 1000'
    2nd round
    Car goes 12.314@110.62, 7.848@87.14, 1.654short. Second fastest pass for this car to date Course car still has the nasty miss going on. Gonna pull plugs and change those today.
    Ed...
    2012 Ram 2500 4x4, 5.7 Hemi, leveled, 35" tires
    2004 Mustang GT - Comp Orange/5speed Best 1/4 11.94@113.64, 1/8 7.59@89.48, 1.57 60' - Best 60' 1.51, just a NA 2v
    nice runs if you get that mis figured out it will pull even better out the back door
    Pittsburgh, PA
    2,363
    Swapped out plugs today. Pulled the NGK Iridiums and they looked ok. Still all gapped at .053" Light brown on insulation but back side of grounding tip was yellowish. I guess from additives in todays fuel?
    Replaced with Champion coppers and gapped to .045" Suppose I'll hit up TnT this week and see how it goes.
    Ed...
    l3@l)&#l_#$$ AdamantiumSilvr's Avatar
    Dec 2008
    Natrona Heights PA
    3,056
    Nice #'ers Ed! Get that miss figured out. Then just get a little bit more out of her, and it'll be high 11s N/A!!
    Bu-2000-bash
    ALLSQUAD
    Steel City Muscle Cars
    CarCruises
    Flashlight Drags
    NMRA
    UMTR
    Modded Mustangs
    NHSCC
    never stock biminiLX's Avatar
    Beaver
    2,406
    Very nice, got her working well!
    -J
    '91 LX Bimini Blue
    427"/88mm on 16psi
    '99 Contour SVT
    Clean DD
    Polar Vortex
    6,031
    Are you putting the blower on this winter?
    Is that the stock gap for those plugs? I'm wondering if your gap was a little less, the strength of the spark would be stronger, might help reduce the miss?
    ChuckT
    Sponsored by
    Wholesale Transmission - New Kensington
    Millerstown Pic A Part
    Pittsburgh, PA
    2,363
    Quote Originally Posted by CobraII View Post
    Stock is .052-.054" and I had last set at .053"
    This set I am going to try at .045"
    Quote Originally Posted by John4cam View Post
    Yes. Few things still to buy yet. Current goal is to go atleast 11.8s or faster making as much power as possibles NA. Hoping my heads are done this week or early next.
    Ed...
  1. went to the track
    By pabadboys in forum Drag Racing
    Last Post: 01-30-2011, 10:52 PM
  2. Track Videos
    By burntire in forum Pictures & Videos
    Last Post: 06-20-2009, 06:12 PM
  3. Track rental 5-7-09
    By 383taman in forum Drag Racing
    Last Post: 06-10-2009, 07:09 AM
  4. Went to the track
    By dpstang98gt in forum Drag Racing
    Last Post: 09-20-2008, 01:25 PM
  5. my old fox went to the track
    By J-rod in forum The Bar
    Last Post: 12-14-2007, 11:08 PM
