Results 1 to 10 of 10
Thread: great reason to use an sfi flywheel
    i follow the work these guys do a little and they were on their way to dyno an engine they were building when they realized the left the flywheel at home, so instead of calling it a day, they decided to use a good stock flywheel they had laying in the shop and the rest is in the video. look at the pics in the upper right hand side...
    [ame="http://s732.photobucket.com/albums/ww328/Bossofu/?action=view&current=100_6747.flv"]Pictures by Bossofu - Photobucket[/ame]
    wow thats sick
    1969 Camaro restomod/project
    1967 camaro
    2011 mustang procharged
    93 reef blue notch blk/int
    92 calypso notch blk/int
    86 t-type
    1972 chevelle project
    2,483
    Didn't sound like it was revving to the moon, but I wonder what rpm it was at when it let go?????
    Dang - that is scary.
    The more I think about it, the less I want to really push my '66 until I upgrade my axles ( stock Lincoln 28 spline ), flywheel ( stock '85 GT ), and install a blowproof bellhousing... It sure is fun to drive as it sits, but I worry about catastrophic failure more these days than I used to...
    And when I fire up an episode of Pinks All Out, I seem to remember the bad runs ( blown engines, busted axles, torn driveshafts, mid-track wipeouts ) more than the good ones.
    Part of getting old, I guess...
    never stock biminiLX's Avatar
    Beaver
    2,406
    Wow, poor Boss 429
    Leechburgistain Mainland,Cuba
    1,534
    Expensive mistake!
    289 slabside cobra
    6S1941
    It made 755/700 with some restrictive dyno headers on pump gas and a mild hydraulic roller. Gotta love BBF's. But then again.....that's an expensive piece for a street car. I would say 16k+.
    wow..
    Dec 2008
    Natrona Heights PA
    3,056
    Danggg, that's tuff!!
    Bu-2000-bash
    ALLSQUAD
    Steel City Muscle Cars
    CarCruises
    Flashlight Drags
    NMRA
    UMTR
    Modded Mustangs
    NHSCC
    Member torqueboxer's Avatar
    white oak, pa
    638
    16,000 then you can start buyin parts to put the short block together!!
    hot rod just put together a "fake"429 with the new john kaase repro retrofit parts my rough math put that build at 25,000,,,a motor adds up fast when just the valve covers cost 1500$ not to mention the 2000$ accessory drive on the motor in the vid!!
  1. Another reason to hate the Flyers.....
    By TJH64 in forum The Bar
    Last Post: 09-06-2011, 05:07 PM
  2. 5.0 50oz SFI Automatic Flexplate/Flywheel
    By mustang50lx in forum Ford Vehicles
    Last Post: 03-20-2011, 08:56 PM
  3. Spec steel SFI flywheel 6 bolt
    Last Post: 02-08-2009, 04:16 PM
  4. another reason to like mccain
    By GOT SVT in forum The Bar
    Last Post: 09-27-2008, 10:43 PM
  5. Another reason to welcome 2007
    By Silverhatch in forum Pictures & Videos
    Last Post: 01-04-2007, 12:41 AM
