Results 1 to 8 of 8
Thread: Nitto D.R.'s hook...
    Not Bad for 367 SAE RWHP Pure Stock's Avatar
    3,499
    NMRA Factory Stock incrementals from B.G. This entry runs E7's and a Cobra intake. All motor. Roughly 311 c.i. Pass from round 1 elim.
    1.558
    4.491
    6.997
    98.230
    9.177
    11.038
    120.76
    2011 Mustang GT, MT-82, 3.73's :
    BONE STOCK 12.223@115.18
    dawg gone thats moving out with e7s!!!
    from my calculations, pretty close ideal et to mph package
    Senior Member White5.0's Avatar
    State College, PA
    3,552
    thats impressive for e7's
    2013 Mustang GT
    1987 Mustang GT
    1999 Contour SVT
    Senior Member Ares's Avatar
    Pittsburgh, PA
    2,363
    Are Mickeys still not allowed in Factory Stock?
    Ed...
    2012 Ram 2500 4x4, 5.7 Hemi, leveled, 35" tires
    2004 Mustang GT - Comp Orange/5speed Best 1/4 11.94@113.64, 1/8 7.59@89.48, 1.57 60' - Best 60' 1.51, just a NA 2v
    Senior Member scott5's Avatar
    NC
    10,168
    Quote Originally Posted by Ares View Post
    I dont think, they were supposed to let loose this year in drag radial class but still not allowed only BFG
    3,499
    Quote Originally Posted by Rodeheaver's View Post
    1.17d) HEADS, PORTING: Prohibited. Runners and combustion chambers must retain OEM appearance and dimensions. Final acceptance at the discretion of NMRA Technical Department.
    1.21 INTAKE MANIFOLD
    INTAKE MANIFOLD: Only NMRA accepted commercially available, mass-produced intake manifolds permitted. Any height spacer permitted between EFI upper and lower intakes only. All runners must be completely separated from each other runner. Spacer or gasket must not create a 'plenum', or any other means for air to pass between runners. 4.6L 4V combinations may remove secondary runner controls. 2V engines only may use aftermarket as-cast throttle-body to intake manifold plenums.
    1.21a) PORTING: Prohibited.
    1.21b) WELDING/EPOXY: Prohibited.
    3,499
    5.1a) PERMITTED STREET-TYPE DOT RADIAL TIRE LIST:
    BFGoodrich Comp T/A Drag Radial
    BFGoodrich G-force T/A Drag Radial
    Nitto NT555R Drag Radials
    Also accepted: any approved radial-construction tire with a D.O.T. tread wear rating of 180 or greater that fits all other criteria and sizing.
  1. UPR Triple Hook Quadrant
    By somethingclever in forum Ford Vehicles
    Last Post: 05-01-2009, 10:05 AM
  2. how to hook up tach
    By stangfever in forum The Bar
    Last Post: 05-14-2008, 10:40 PM
  3. Does anyone have a tire hook-up?
    By Cam99 in forum The Bar
    Last Post: 05-14-2008, 08:39 AM
  4. Welcome to the house of hook!!!!
    By Sonic03snake in forum Pictures & Videos
    Last Post: 12-12-2007, 03:46 PM
  5. Can you say HOOK!
    By 351SVT in forum Pictures & Videos
    Last Post: 09-12-2006, 10:08 AM
