Results 1 to 14 of 14
Thread: 2010 Mirrors For S197 (05-09)
    Black 14 GT500 JT3's Avatar
    34
    Time to give back to the Internet.
    Here's a project I've been wanting to do since I bought my 06 GT - replace my factory trucker mirrors. I looked at Agent 47 and various mirror covers but IMO neither was the right solution. I bought a set of 2010 mirrors from Ford and here's the result and process if you're interested in this mod:
    Left and Right Comparison:
    Driver Side:
    Passenger Side (OEM):
    Driver Side (close up):
    Passenger Side (OEM close up):
    Driver Side (close up 2):
    Passenger Side (OEM close up 2):
    INSTALLATION
    The 2010 mirrors obviously don't come with instructions. And as of today, they're not available prepainted. Here's a brief description of the process. Unfortunately it's not plug-and-play...
    1) From the inside, remove the triangular plastic panel. It pops right off.
    2) Disconnect the wiring harness from the plastic panel (there are two on the driver side).
    3) Remove the three nuts that are attached to the mirror studs. Hold the mirror because it will fall off the door.
    Now the fun begins:
    4) On the new mirror clip off the two plastic studs. It's best to carefully remove the triangular foam padding in order to clip close to the base of each stud.
    5) The 2010 metal studs do not align perfectly with the factory holes, so get out the drill. The two holes towards the back of the car need to be made larger, and a new hole needs to be drilled towards the front of the car. Cover the exterior of your door to prevent scratches and the interior to prevent metal shavings from falling inside the door panel. Test fit your parts first and wear goggles before drilling.
    Exterior views (passenger side):
    Interior view (passenger side):
    6) Test fit for accuracy. If okay, you can sand or file the metal burrs, and paint the bare metal with touch up paint.
    7) Install the new mirror using the reverse procedure mentioned above (3, 2, 1). Take time to position the mirror over the exterior trim in the same position as the OEM.
    Here are the tools I used, plus a vacuum...
    And the finished result:
    Fuwkawee
    5,151
    Looks kick ass Joey
    Saw them at Moon Cruise
    So what does she weigh?
    17 Ram 1500 Big Horn Hemi
    16 Comp O GT Performance Pack
    Sep 2008
    555
    Nice, definitely a huge improvement over the stockers. I went with the Agent 47s and I'm ok with them. Takes a bit to get used to the smaller mirror.
    Live free or die
    Senior Member pop's stang's Avatar
    Dec 2008
    Belle Vernon, PA
    854
    Very nice!!! Will have to keep that in mind!!
    "If speed wasn't important, it wouldn't be called the human race!"
    2,247
    Those look great IMO. good choice!
    Black
    Jun 2007
    N. Huntingdon
    1,596
    Stunning
    Chris
    2016 Chevrolet Volt
    2010 Jetta TDi Cup Edition
    1964 Lincoln Continental
    34
    Thx Kev. 3560 on half tank; no bodies.
    14 Black GT500
    Stock. So far.
    SOLD 06 Black GT
    Hurst, Eibach, Steeda, Magnaflow, Wilwood, FRPP Cams, 3:73, Powerhouse Aluminum Driveshaft / Intake / Tune, 363hp on Mustang Dyno
    34
    Thanks for the positive feedback. If anyone has any questions I'd be happy to help.
    I was close to the A47 mirrors - they're also a good choice!
    14 Black GT500
    Stock. So far.
    SOLD 06 Black GT
    Jan 2009
    Masontown, Pa.
    1,618
    Looks great man! The whole car does!!
    Aug 2008
    State College PA
    2,326
    WOW ... I didn't realize how different the 2010's mirrors were! Looks great on your car!
    PICS & Dyno
    JB 412mustangz's Avatar
    Apr 2009
    West Mifflin
    1,247
    wow that looks so much nicer than the stock mirrors! great idea
    DD: 99 Civic Si
    Toys:
    07 GSXR 600
    needs boost! wishIhada5.0's Avatar
    May 2008
    right outside of Greensburg
    352
    That looks really nice...very clean lookin
    made some noise....and some boost...and 377/442 rwhp/rwtq
    Nice write up.....looks way better.
    NICE! I love subtle mods like that. They look like they should have been on that car from the day it was made!
  1. 96 - 04 painted mirrors
    By 2000GT in forum Ford Vehicles
    Last Post: 09-01-2014, 09:45 PM
  2. Big Mirrors
    Last Post: 04-13-2010, 11:10 PM
  3. 03-04 cobra mirrors?
    By 94svtcobra in forum SN95-New Edge
    Last Post: 08-20-2008, 05:11 PM
  4. Mirrors. Big ones.
    By coralcoupe1993 in forum For Sale
    Last Post: 10-07-2007, 12:06 AM
  5. Mirrors – Big ones. Come get em.
    Last Post: 10-01-2007, 03:34 PM
