Results 1 to 9 of 9
Thread: Pulling heads
    In a Time Machine
    3,361
    Pulling heads
    what all is there to taking the heads off my car, I know there is a certain pattern you have to follow, but not sure what that is. also the guy buying my heads asked to not take the roller rockers off to just to leave them loose. first time doing this so any input is appreciated
    2,247
    I don't have any advice, but it sounds like it's going to me a PITA. lol Good luck man
    Black
    State College, PA
    3,552
    there is no pattern to loosening the bolts. you can just take them off in any order...there IS a pattern when putting your new heads on though so dont forget that. Also, you can just loosen your rockers and turn them to the side so you can get your pushrods out. dont need to waste time taking them off unless you are going to use them on your new heads.
    just take out your head bolts, pull out your pushrods and pull the heads off. you might have to pry the heads a little they might be tough to pull up but dont worry thats what usually happens
    2013 Mustang GT
    1999 Contour SVT
    In a Time Machine
    3,361
    Thanks
    If you need help mike let me know and me and my buddy can stop over and give you a hand. I did it to my red 95.. Not that bad at all
    Jan 2008
    Jefferson
    4,674
    when you reinstall BUY NEW HEAD BOLTS!
    In a Time Machine
    3,361
    I planned on it
    I always loosen my head bolts the initial 1/8th-1/4 turn in the reverse pattern that they are installed as to ensure I don't warp them. Once the major tension is off of the bolts then I remove them all the way out in no particular order. Loosen the rockers BEFORE you loosen the head bolts.
    Feb 2009
    Latrobe
    517
    to take parts off all you do is loosen bolts dude just just keep your header bolts u will need arp head bolts and intake bolts for the new stuff neway
    i think a 5 year old could do this job
    PROBE PISTONS
    PROBE BILLET I BEAM
    super victor
    230cc CNC
    Hooker 2 in headers
    pa sc c4, 4600 stall
    9" LADDER 3.70 PRO GEARS
    SW BACKHALF
    moser 35 SPLINE axles
    1050 RACE DOMINATOR DEMON
    250 FOGGER KIT
    snow performance stage 2
    1.316 60ft 9.16@156
  1. GT40 3 bar iron heads,NOT P HEADS!
    Last Post: 07-05-2014, 03:14 PM
  2. pulling my motor from my 88 gt
    By matty g in forum Fox-SN95
    Last Post: 04-12-2012, 11:28 AM
  3. Pulling engine with LT Headers
    By Mitternacht in forum S197
    Last Post: 06-23-2008, 07:13 PM
  4. Buske portable pulling tower
    By JC Turbo in forum Ford Vehicles
    Last Post: 01-03-2008, 08:38 PM
