Results 1 to 4 of 4
Thread: Need Electrical gurus help...charging problem.
    Twin Turbo Saleen 98saleen's Avatar
    179
    Question Need Electrical gurus help...charging problem.
    When I initially crank my car (cold) it starts right up and charges properly from the alternator.
    The Problem -
    When the car reaches normal operating temperature, it will refuse to idle. Car will run if you press the gas pedal and will cruise on the highway fine.
    But when you come to a stop, the idle will drop so low the car cuts off.
    During this time, the alternator is charging still.
    I've changed 2 alternators (one newly rebuilt and one my old standby stocker) and both do it.
    I've traced the problem to the actual charging of the alternator.
    If I unplug the car wiring harness from the alternator, the car will idle perfectly (cold, warm, or hot it does not matter).
    Just as soon as I plug the harness in, the car will die.
    With the serpentine belt off and car running, I've tried to turn the alternator by hand and it doesn't spin easy.
    With the harness unplugged, the alternator spins perfectly fine.
    I believe the alternator has too much of a load or something on it making it hard to spin and this causes the car to die.
    So what do I need to look for to fix this? Is there a diode or something that could have gone bad causing this problem?
    It just started about a week ago.
    Thanks,
    Ryan
    Dec 2008
    Natrona Heights PA
    3,056
    Someone on here can help a brotha North Carolinain out!
    Bu-2000-bash
    ALLSQUAD
    Steel City Muscle Cars
    CarCruises
    Flashlight Drags
    NMRA
    UMTR
    Modded Mustangs
    NHSCC
    179
    Still not figured out yet.
    Alternator seems to be working corrrectly.
    I had the shop check it and my stock one again yesterday and they were fine.
    The 3 pin connector on the side of the alternator is getting the correct voltages.
    Battery checked out fine (no dead cells).
    So now I'm thinking it is something to do with the load on the engine.
    Adding the alternator load just puts too much on the engine and bogs it down.
    Weird how it happens only when the car is up to normal operating temperature.
    Wonder if something in the tune can be adjusted?
    Is there anything about the power steering that could do it?
    Ryan
    Huntingdon PA
    1,136
    Are you sure this isn't a ground problem? Too many grounds are never enough..
    709RWHP/750RWTQ
  1. Electrical problem in Ranger.....HELP
    Last Post: 07-13-2013, 10:16 PM
  2. 99 Cobra with supercharger - Gurus Come In
    By phillysrt4 in forum SN95-New Edge
    Last Post: 07-24-2012, 09:28 AM
  3. Charging problem
    By crazylou in forum General Tech
    Last Post: 07-05-2010, 08:50 PM
  4. Tire gurus come inside
    By Sonic03snake in forum General Tech
    Last Post: 04-24-2007, 05:21 PM
  5. for all engineers or math gurus
    By venom in forum The Bar
    Last Post: 02-02-2007, 12:41 AM
