1993 F150 Regular cab. I have have had alot done to it. Just wondering if there is any interest out there for it. New parts on the truck are, front brakes,rotors,calipers,heavy duty spring, rear shoes,drums,wheel cylinders, parking brake cables, 3/4 ton springs, all four shocks, wiper pump, wiper motor, shifter shaft, 31' tires, exhaust from cat back and air pump tube repaired, spark plugs, cap and rotor, rear gear bearings, both front and rear gas tanks, fan clutch, radius arm bushings, air filter, transmission service, coolant changed, serp. belt. 4wd works, a/c is cold. Has power windows, automatic, intermitent wipers, cd player.
The bad
Needs a windshield
Engine has about 40,000 miles since rebuild, odometer reads 235,xxx
Rear fenders showing rust
2750 obo or trade for something 4 door ( found out wife is due in July )
