Cant really think of any other way to say this one. I have been wanting to tuck my wires for a long time. I did a good bit over the last few years. But, now I figure its time to do all of it and be done. I will update as progress gets done.
Looks good Rob![]()
HAHAH Yeah, Bob, thanks. HAHAHAHHA But I will say, I am adding an Eaton carrier so my car does not end up like yours on its first pass out with sticky tires. HAHAH Thats along with the "to do" list this year.
Give it time Scotty!! Give it time.![]()
good luck , you can unplug and reroute alot fo the drivers side ones just make sure they are all plugged back together
Driver side was completely hidden last year. I lengthened a few wires to get it done. The main harness is going to be the bitch though. With it all opened up, the 1 ten pin connector goes free to the passenger side. The other has a couple wires that go to the drivers side and they will need pulled put of the respecting connectors and re-routed/lengthened to get back to where they are now. I like how Ford uses basically 2 grounds and tie multiple wires off of it. Such morons. 2 to the ECU and four to various places all meeting in the center. Shouldnt be too hard though. Hardest part is going to be welding all the holes up.
Also moving the baro sensor inside the car and the vacuum tree into the inner fender or cowl. Not sure yet which way to go with it yet. Pulling the master and booster this weekend.
Parts are arriving finally. Will get some pics up soon. Got an Eaton carrier. Edlebrock Victor5.0 intake, ordered my Team Z front end kit. The one with K-member, tubuar arms and coil overs. Dave said it should be here by Thursday, friday at the latest. Its finally coming together, or apart. Depends on how you look at it. HAHA Dash is almost out now and the fender will be coming off tomorrow. New heater core going in and probably an A/C evaporator.
sweet sweet!! This whole wire tuck thing SOOOOO looks like something I should steer clear from!! Right Rob? hahahahahha
Looks good :)
-Frank-
1986 GT-- HCI
2011 WRX
1999 B2500 7.5/9 drop
Soon Robert. Soon. After everything arrives I will get some.It may be too much to handle for some folks. HAHAHAHAHHA
Sweet Rob, that is a serious project, but well worth it in the end!
Got some more done today. These dashes are a bitch to get out but worth it. My heater core was leaking like none other. I by-passed it last year. But with my son riding with me in the car I figured it was time to fix it. Its easy to get apart out of the car too. HAHAHAHA
