HA, yeah. Lets see a Honda make powa like this. Might take 6 of them.
rob will a different length blower belt help your clearance trouble at water pump?
Troy, with the 8" lower and 3.33 upper, this is about the only length belt I could use. Its a 57.5 length. I am sure the belt will stretch a little abd give me a tiny bit more room. I did a lot of search on which one to use and measured a ton. Next option is to turn a couple thousandths off the Votech water pump pulley right at the edge. Currently, the belt is about an inch from the other side at the contact point.
Rob, I have Energy susp poly mounts in now. With the coupler, it should have enough give to allow any engine movement to not cause any problems. I made the holes a little larger than what was needed and ran a piece of vacuum line split down the center as a cushion/noise barrier. My old combo made a nice rattle noise without that done. Thanks also man!!
Seen one make WAY more power than you're going to!![]()
[ame]http://www.youtube.com/watch?v=OCA6tcitSMM[/ame]
I think it may of made the most power on Hybrid's dyno unless Robert's Supra topped it.
Where did you ever come up with such an ingenious idea? :D
I wouldnt say way more power either. I might be real close to that. Depending on how much nuts I have with Dave at the controls. It is getting trailerd so that adds a little confidence.
Just another high powered car that didnt run 12's![]()
1969 Camaro restomod/project
1967 camaro
2011 mustang procharged
93 reef blue notch blk/int
92 calypso notch blk/int
86 t-type
1972 chevelle project
All done except for the meter that must have went to Jamica before it comes to my house and the AC wires that need pulled through the hole in the HVAC box, thata what the silver wire is thats going up the firewall... And the part that GMkiller got me from summit yeaterday. Depending on those dip-shit Pro-M fools, this thing will run this week.
The shot of the AC line is for Eddie.
This thing went12's. HAHAHAH Soon it could be saying "went10's" HAHAHAHAHHAH Thats gonna take alot of seat time though.
Just noticed, I have to re-route one more harness too. The A/C compressor harness. Its hanging right by the inlet pipe. Damn.
what kind of caster camber plates are those??
03 Torch Red Anni. Ed. Cobra
01 cobra: traded
93 LX Modular 4v swap
What did you end up doing for the throttle cable bracket?
15gt
94gt
CC's are AJE. Throttle cable is a braided stainless one. I modified the stock bracket. A little trimming, cutting and re-welding and it fit. I had to shave a good bit for the IAC though. That was the hardest part. I think if I ever go to a FAST system or an AEM, I will incorporate a GM IAC and flip the TB over. I was going to do it this time but it just didnt look right with the huge Ford IAC motor.
Im guessing your running those CC plates with coil overs?? how do you like them?
01 cobra: traded
I love the look of the intake flipped. I bet others will try to do the same. Good work!
You going to polish those pipes? looks good man ;)
Yes, I have the whole Team Z front end. Coil overs, tubular K and Tubular arms. So far, I like them. I gotta drive it though to see how they work.
Thanks Jason!!! I am sure some will. I must have missed Ed with his pictures when he showed his thoughts on his car a long time ago.
Yeah Bob, I probably will. I want to get it running and get a piece of mind. Lower my stress level a little bit. Then I will pop them back off and polish them. Thanks a lot!!!!
Looks great Rob!!But don't kill yourself putting it together...this freakin snow isn't going to melt until July...
I hear ya Ron. Its more of I want to get it running now. Once it runs and I get some idle time on it with a few warm ups to make sure everything works like the fans and there are no glitches, I can relax some. Take the rear out and polish the inlet pipes to the T/B. The rear end shouldnt take more than a weekend. Just swapping out the carrier to the eaton and installing the FMS cover, and arms.
