HAHAH Gotcha Tony!! Do you have the plug?
Yes. The Ford kit comes with everything in the world to do the conversion right. Except for the nut to hold the new prop valve to the strut tower. (different stud threads)
The proper plug and prop valve were already installed at the time of the picture.
Do you need/want the plug? The only reason it is not in that picture is because I was showing the parts that got removed and the instructions to someone on MustangForums. I guess the plug that is shown in the picture has the hole and cap on it to release air pressure as the plunger is compressed, but I do not know for sure.
Sorry to keep posting pics, but here's the good ol' Sn-95 valve with the proper port on it(front side). By the way... if you do go this route, you will need an adapter for the rear most port. You should be able to see it in the picture. I love me some stainless steel lines... :)
I never knew they had a kit like that, interesting.
I just got rid of that ugly factory prop valve.
I also use a '94 Cobra MC and from the rear port use a Wilwood prop valve to the rears and the front port goes to a line-lock and then to each front.
Very clean and simple.
I understand using the stock prop valve as just a distribution block to save making new lines. I did it that way for a while, then just cleaned it up like I mentioned, looks much better.
That sounds like a good set up bimini. I'm not that heavy into drag as much as autoX, so I opted to not put a line lock in. I considered it for a long time though.
Damn Rob, did this project snowball from one or two upgrades to an almost total rebuild, or was that the plan all along ?
Keep the updates coming. I love following a big project thread.
Well Frank, it started as a heater core swap. HAHA When I didnt have enough fuel at one of Lunds tuning days here I decided to sell the whole fuel system and start over with a sumped tank. Then I sold the motor that was in it. Then I said I am going to smoothen the engine bay. Then I just got carried away. HAHAHAHHA
can't polish a turd rob, lol
call me I'm at work, I have a prop. valve
Did some work today. Finished welding and started some filler. This is the first skim coat. Ran out of hardener. Will get some more done this week.
Gotts pull the CC plates off and the brake lines. Thata bout it. Throttle cable too. Sand it, make it pretty, let it sit for a week then spray it. Then the fun starts. Hoping I remember how this thing goes back together. HAHAHA
Couple more. Stayed up late the last couple nights and got a good bit dont. Put a light coat of primer on to see how everything looks.
With a little bit of wet sanding and a couple more coats of primer it will be ready for paint. Still have to pull the front suspension out but thats only about an hour job tops. Probably less than that. Then the color goes in the gun and it gets sprayed.
nice rear end in the back ground LOL
HAHAHA Thanks pal. HAHAHAHAHHAHA![]()
