Results 1 to 11 of 11
Thread: smog pump help
    butler pa
    337
    smog pump help
    my smog pump is making a howling noise and i need to know if its bad it throws a code at different times like sometimes after 8 miles and some times under a mile i dont know if thats the reason that the check engine light comes on any help would be great
    Senior Member 95gts's Avatar
    Sep 2008
    Brownsville
    290
    94-95's are a pain in the a**!!! The Engine light could be on because that, they have sensors that read the smog tubes or something like that.. but i also know that every 94-95 i have seen has the ces light on... the computers are just really sensitive and pretty much come on for no reason. and especially if you have mods.
    95 Mustang gts... Cobra intake,GT40P heads, F-cam, sds efi, 60lb injectors, Garrett turbo 11lb's!!!
    It could be related. Have you had the car scanned to see what codes its showing?
    I've never had a check engine light come on for no reason in either of my 94-95's.
    Get a code scanner and see what the codes are.
    butler pa
    337
    Angry
    its showing code a theromcore bank 1 and 2 below thresh hold and a egr opeining not detected scince then i have replace the egr and the smog pump because of the damn noise it was making and i still am having the check engine
    The thermactor are the tubes that run between the heads on the firewall side of the engine. There is a tube that connects them to the tube coming from the airpump to the catalytic converter. I'd inspect it for holes/leaks and try to find a way to test the little valves that are in those tubing lines below the throttle body near the strut tower.
    butler pa
    337
    i replaced the valves ill have to check the tubes
    Chevelle Owner Tony71502's Avatar
    Jun 2008
    Bell Acres
    469
    I'm guessing the CEL is from a bad o2 if it comes on and off like that.
    1991 Jewel Green Ford Mustang LX ~ 5.0L / 5-Speed
    2011 Torch Red Ford Ranger ~ 2.3L / 5-Speed
    1971 White Chevrolet Chevelle Malibu w/ Blue Stripes ~ 8.2L(502) / 4-Speed
    butler pa
    337
    i just replaced thoes when i put my o/h h pipe on
    Sep 2008
    Brownsville
    290
    have any luck on gettin light off yet??
    butler pa
    337
    yeah my egr tube was cracked and now it comes on much less but still comes on
  1. Smog pump delete?
    By PITT40 in forum Fox-SN95
    Last Post: 06-18-2010, 10:32 AM
  2. Wanted- 94-95 Smog Pump
    By gmkillr in forum Ford Parts
    Last Post: 02-21-2010, 05:14 PM
  3. smog pump removal?
    By firsttime5.0 in forum General Tech
    Last Post: 07-21-2009, 08:21 PM
  4. smog pump elimination
    By badf250 in forum Fox-SN95
    Last Post: 03-17-2008, 09:07 PM
  5. fox smog pump
    By PSPstang in forum Ford Parts
    Last Post: 09-26-2006, 05:51 PM
