Results 1 to 3 of 3
Thread: Dip stick passage in block issue
    Go big or go home... gmslayer's Avatar
    Nov 2008
    Latrobe, PA
    347
    What can be used to block off the hole in the engine block for the dip stick in order to use an oil pan mounted dipstick like on a Canton oil pan??
    Thanks!!
    A bolt and some good sealer. I use motorcraft stuff from Ford. Its the same stuff you can get at advance auto in the gray tube.
    you could get a tiny softplug or get an old dipstick and cut it off flush and have it welded shut..
  1. 324 Boss Block Big Bore Stroker short block $2,900 O.B.O.
    By Stroked03Cobra in forum Ford Vehicles
    Last Post: 05-03-2014, 04:19 AM
  2. Replies: 14
    Last Post: 02-22-2014, 01:52 PM
  3. dip stick problems
    By fryer19 in forum General Tech
    Last Post: 05-15-2010, 09:56 AM
  4. oil dip stick
    By yellowstang03 in forum The Bar
    Last Post: 03-21-2008, 12:47 AM
  5. need major HELP - DIP STICK related
    By J-rod in forum Fox-SN95
    Last Post: 02-09-2007, 06:11 PM
