Results 1 to 4 of 4
Thread: V-8 conversion wiring question
    Senior Member oldfox's Avatar
    May 2009
    296
    Hi, I have a 91 fox that I am going to change over to a V-8. For a donor car I have a 89. I have been reading the post and threads on this but I still have a question. From what I have seen it looks like I will need to use the 89 wiring harness. But will I need to change all of the harness?
    Like pull the dash and switch all the wires? Or does the harness have just sections that will need changed? And if i do need to change everything will it all plug in ok to the 91 switches?
    any help would be appreciated Lee
    Mt Pleasant, PA
    4,905
    I have a 91 efi harness I would trade for your 89 if interested. Should be a direct plug in then.
    out in the woods
    4,948
    need 89 to switch over to mass air on 87-88 v8
    90 stands alone in all wiring
    91-93 is compatable
    ive done this many times and did alot of research,so no the 89 harness will not work with 91 wiring. plugs are different on driver's side under hood.
    2003 polaris predator 500
    (wanna ride,just pm me!!!)
    FREAK Freakingstang's Avatar
    Nov 2009
    Akron, Ohio
    77
    Quote Originally Posted by INSANELY CRAZY View Post
    91-93 is compatable
    this is correct, unless you want to cut and splice.....Done a few myself, don't recommend cutting and splicing unless you solder all the connections. Wire nuts, butt connectors, spade terminals, etc don't belong in this application.
    03 SB Cobra Vert-472/495 to the wheels via Street Lethal
    86 GT VERT-342, S trim, TFS, RPM, etc
    1966 Coupe-EFI conversion, T5 and lots of work ahead
  1. Wiring question help!!!
    By How Much? in forum The Bar
    Last Post: 02-01-2012, 11:52 PM
  2. Transmission wiring question
    By Darren in forum General Tech
    Last Post: 03-07-2011, 01:43 AM
  3. Basic air conditioning wiring question
    By oldfox in forum General Tech
    Last Post: 02-17-2011, 01:58 AM
  4. Wiring question for Sn95 guys
    Last Post: 07-31-2009, 05:22 PM
  5. another conversion question
    By 92306gt in forum General Tech
    Last Post: 03-23-2008, 02:18 AM
