Results 1 to 20 of 26
Thread: Parting out 89 SSP Turbo Project
    Charleston, WV
    46
    Car and parts are located in Charleston, WV.
    Mike Elswick
    AIM - Warriorblaze86
    Email - Warriorblaze@gmail.com
    PM me for cell phone number.
    I know I'm not a regular poster on this forum but I am also on Corral.net and an Admin on WVMotorsports.com (same screen name).
    89 Mustang Coupe SSP (Special Service Package)
    10pt roll cage
    8.8 rear end
    4.30 gears
    Battle boxes
    Tubular upper and lower control arms
    Rear lowering springs
    Moroso Trick front springs
    Strange 10 way adjustable front struts
    Power windows
    20% tint
    Cobra R/SVO hood with pins
    Weld Draglites 15x3.5F 15x8R
    165r15 skinnies
    26x11.50/15 M/T ET Streets (very low miles)
    Car is VERY solid, NO RUST. Doors and trunk open and shut like a bank vault.
    [ame]http://i34.photobucket.com/albums/d138/WarriorBlaZe/DSC00238.jpg[/ame]
    [ame]http://i34.photobucket.com/albums/d138/WarriorBlaZe/Buford1-c.jpg[/ame]
    $2000
    BG Custom Fabrication Single Turbo Kit
    1 5/8" Primaries
    2.5" crossover with flex joint
    Single T4 turbo flange
    3.5" downpipe
    All connections are V-band
    Masterpower T70 .96 A/R turbo
    Tial 44mm wastegate
    Tial 50mm BOV
    33x12x4 Bar and plate intercooler
    3" cold side piping
    Silicone couplers
    T-bolt clamps
    [ame]http://i34.photobucket.com/albums/d138/WarriorBlaZe/Turbo/P9120017.jpg[/ame]
    [ame]http://i34.photobucket.com/albums/d138/WarriorBlaZe/Turbo/P9110014.jpg[/ame]
    [ame]http://i34.photobucket.com/albums/d138/WarriorBlaZe/Turbo/P9170017.jpg[/ame]
    [ame]http://i34.photobucket.com/albums/d138/WarriorBlaZe/Turbo/P9170016.jpg[/ame]
    [ame]http://i34.photobucket.com/albums/d138/WarriorBlaZe/Turbo/100_1753.jpg[/ame]
    [ame]http://i34.photobucket.com/albums/d138/WarriorBlaZe/Turbo/100_1758.jpg[/ame]
    $2500
    5.0 Long block
    Stock shortblock
    Ported TFS Twisted Wedge heads
    Comp Cams Magnum Roller Rockers and Poly locks 1.6 ratio
    TFS Hardened 3/8" 6.700 pushrods
    ARP Pro Series Head Studs
    Felpro Head Gaskets
    Powerbond SFI spec balancer
    $1500
    PA SuperComp C4 (full swap)
    PA SuperComp C4 with transbrake
    PA SFI Spec Bellhousing
    TCI 50oz SFI flex plate
    TCI 3500 stall converter
    Locking dip tube
    Deep trans pan
    B&M Pro Stick shifter w/transbrake button
    PA block plate
    ARP flex plate bolts
    [ame]http://i34.photobucket.com/albums/d138/WarriorBlaZe/Turbo/DSC00097.jpg[/ame]
    [ame]http://i34.photobucket.com/albums/d138/WarriorBlaZe/Turbo/DSC00098.jpg[/ame]
    Performance automatic rates this transmission at 1000hp and it has a lifetime warranty. The transmission alone sells for $2,100 plus freight.
    $2000
    Trick Flow Specialties Box R Intake
    Ported lower intake
    Black powder coated box upper
    Accepts 90mm throttle bodies
    [ame]http://i34.photobucket.com/albums/d138/WarriorBlaZe/DSC00250.jpg[/ame]
    $500
    Flaming River Manual Rack Kit FR1890
    Standard Ratio 20:1 rack
    Inner/Outer Tie Rods
    Steering shaft
    Rack Bushings
    Brand New in box
    $400
    Aeromotive Eliminator Fuel pump
    -12 AN inlet
    -10 AN outlet
    Supports up to 1400hp on boosted applications and 1900hp naturally aspirated
    [ame]http://i34.photobucket.com/albums/d138/WarriorBlaZe/Turbo/DSC00365.jpg[/ame]
    $375
    Aeromotive A1000 bypass Fuel Pressure Regulator
    2 -10AN inlet ports
    1 -6AN return port
    1/8" NPT gauge port
    Vacuum/boost port
    Adjustable from 30-70psi
    $100
    Behind Bars Race Cars Fuel Rails
    Dual inlet/outlets
    CNC Machined
    Angled for distributor clearance
    Supports up to 2000hp
    Includes AN fittings
    [ame]http://i34.photobucket.com/albums/d138/WarriorBlaZe/Turbo/DSC00366.jpg[/ame]
    $200
    SN-95 Spindles (5 lug)
    From 95 model car, maintains stock track width
    Allows use of SN95/Cobra brakes
    Includes hub assemblies
    $100
    Edelbrock Performer Intake
    [ame]http://i34.photobucket.com/albums/d138/WarriorBlaZe/coupe4.jpg[/ame]
    $250
    Spec Stage 3 Clutch
    10 spline
    6 puck
    Sprung Hub
    Low miles
    [ame]http://i34.photobucket.com/albums/d138/WarriorBlaZe/Turbo/DSC00123.jpg[/ame]
    [ame]http://i34.photobucket.com/albums/d138/WarriorBlaZe/Turbo/DSC00122.jpg[/ame]
    $100
    I'm sure there is more that I'm forgetting, I'll update this thread later when I think of things.
    There is over 10k worth of parts, etc here. I will sell it all for $9,000. Just pick your stand alone, finish the fuel system and a few odds and ends to be up and racing.
    Not willing to part anything out other then how I have it listed at this moment.
    Thanks for looking.
    Charleston, WV
    46
    Sale pending on clutch.
    Charleston, WV
    46
    Bump
    In a Time Machine
    3,361
    clutch still available?
    Charleston, WV
    46
    Clutch is pending to BadstangLX.
    If it isn't sold by Friday I will let you know.
    South Hills, PA
    4,052
    do you have any interior for the roller? dash, etc....
    the rails are $200?
    Dealer for:SCT,Maximum Motorsports, Kenne Bell, JLT,and many more.
    Charleston, WV
    46
    The dash has been trimmed for the cage and installed back in the car. I have the rest of the interior but it is not installed.
    Charleston, WV
    46
    Quote Originally Posted by Bob@Streetlethal View Post
    the rails are $200?
    $200obo
    What year are the spindles from? 94-95, of 96+?
    Charleston, WV
    46
    94-95
    Quote Originally Posted by Warriorblaze View Post
    94-95
    I'll offer you $60 shipped for them.
    Charleston, WV
    46
    No thanks.
    Charleston, WV
    46
    Haven't gotten any word from Badstanglx.
    Clutch still available.
    No thanks.
    OK. If you change your mind in the next week let me know. Otherwise I'll just grab a set out of the bone yard.
    Charleston, WV
    46
    Bump
    FREAK Freakingstang's Avatar
    Nov 2009
    Akron, Ohio
    77
    Pm returned, send me some pics of the updated dash installed, I'm not worried aobut the rest of the interior, I have a full black interior in my rotted out 89.
    stang86gt@hotmail.com
    03 SB Cobra Vert-472/495 to the wheels via Street Lethal
    86 GT VERT-342, S trim, TFS, RPM, etc
    1966 Coupe-EFI conversion, T5 and lots of work ahead
    Charleston, WV
    46
    Bump
    Charleston, WV
    46
    Sale pending on roller
    Charleston, WV
    46
    Buyer backed out. Roller is back up for sale.
  1. 95 Turbo 5.0 Project
    By 95gts in forum Fox-SN95
    Last Post: 10-01-2013, 02:22 PM
  2. Bought a SSP notch
    By JOlbert in forum Pictures & Videos
    Last Post: 04-29-2013, 07:08 PM
  3. 1988 Mustang SSP Notch project
    By PSPstang in forum Ford Vehicles
    Last Post: 07-01-2011, 08:26 PM
  4. If your lookin for a light 2.3 Turbo project
    By map351 in forum Fox-SN95
    Last Post: 10-14-2008, 07:24 PM
  5. Turbo project DONE ,car is running and its nasty
    By Slow5.0 in forum Other Ford
    Last Post: 12-31-2006, 02:33 PM
