Car and parts are located in Charleston, WV.
Mike Elswick
AIM - Warriorblaze86
Email - Warriorblaze@gmail.com
PM me for cell phone number.
I know I'm not a regular poster on this forum but I am also on Corral.net and an Admin on WVMotorsports.com (same screen name).
89 Mustang Coupe SSP (Special Service Package)
10pt roll cage
8.8 rear end
4.30 gears
Battle boxes
Tubular upper and lower control arms
Rear lowering springs
Moroso Trick front springs
Strange 10 way adjustable front struts
Power windows
20% tint
Cobra R/SVO hood with pins
Weld Draglites 15x3.5F 15x8R
165r15 skinnies
26x11.50/15 M/T ET Streets (very low miles)
Car is VERY solid, NO RUST. Doors and trunk open and shut like a bank vault.
[ame]http://i34.photobucket.com/albums/d138/WarriorBlaZe/DSC00238.jpg[/ame]
[ame]http://i34.photobucket.com/albums/d138/WarriorBlaZe/Buford1-c.jpg[/ame]
$2000
BG Custom Fabrication Single Turbo Kit
1 5/8" Primaries
2.5" crossover with flex joint
Single T4 turbo flange
3.5" downpipe
All connections are V-band
Masterpower T70 .96 A/R turbo
Tial 44mm wastegate
Tial 50mm BOV
33x12x4 Bar and plate intercooler
3" cold side piping
Silicone couplers
T-bolt clamps
[ame]http://i34.photobucket.com/albums/d138/WarriorBlaZe/Turbo/P9120017.jpg[/ame]
[ame]http://i34.photobucket.com/albums/d138/WarriorBlaZe/Turbo/P9110014.jpg[/ame]
[ame]http://i34.photobucket.com/albums/d138/WarriorBlaZe/Turbo/P9170017.jpg[/ame]
[ame]http://i34.photobucket.com/albums/d138/WarriorBlaZe/Turbo/P9170016.jpg[/ame]
[ame]http://i34.photobucket.com/albums/d138/WarriorBlaZe/Turbo/100_1753.jpg[/ame]
[ame]http://i34.photobucket.com/albums/d138/WarriorBlaZe/Turbo/100_1758.jpg[/ame]
$2500
5.0 Long block
Stock shortblock
Ported TFS Twisted Wedge heads
Comp Cams Magnum Roller Rockers and Poly locks 1.6 ratio
TFS Hardened 3/8" 6.700 pushrods
ARP Pro Series Head Studs
Felpro Head Gaskets
Powerbond SFI spec balancer
$1500
PA SuperComp C4 (full swap)
PA SuperComp C4 with transbrake
PA SFI Spec Bellhousing
TCI 50oz SFI flex plate
TCI 3500 stall converter
Locking dip tube
Deep trans pan
B&M Pro Stick shifter w/transbrake button
PA block plate
ARP flex plate bolts
[ame]http://i34.photobucket.com/albums/d138/WarriorBlaZe/Turbo/DSC00097.jpg[/ame]
[ame]http://i34.photobucket.com/albums/d138/WarriorBlaZe/Turbo/DSC00098.jpg[/ame]
Performance automatic rates this transmission at 1000hp and it has a lifetime warranty. The transmission alone sells for $2,100 plus freight.
$2000
Trick Flow Specialties Box R Intake
Ported lower intake
Black powder coated box upper
Accepts 90mm throttle bodies
[ame]http://i34.photobucket.com/albums/d138/WarriorBlaZe/DSC00250.jpg[/ame]
$500
Flaming River Manual Rack Kit FR1890
Standard Ratio 20:1 rack
Inner/Outer Tie Rods
Steering shaft
Rack Bushings
Brand New in box
$400
Aeromotive Eliminator Fuel pump
-12 AN inlet
-10 AN outlet
Supports up to 1400hp on boosted applications and 1900hp naturally aspirated
[ame]http://i34.photobucket.com/albums/d138/WarriorBlaZe/Turbo/DSC00365.jpg[/ame]
$375
Aeromotive A1000 bypass Fuel Pressure Regulator
2 -10AN inlet ports
1 -6AN return port
1/8" NPT gauge port
Vacuum/boost port
Adjustable from 30-70psi
$100
Behind Bars Race Cars Fuel Rails
Dual inlet/outlets
CNC Machined
Angled for distributor clearance
Supports up to 2000hp
Includes AN fittings
[ame]http://i34.photobucket.com/albums/d138/WarriorBlaZe/Turbo/DSC00366.jpg[/ame]
$200
SN-95 Spindles (5 lug)
From 95 model car, maintains stock track width
Allows use of SN95/Cobra brakes
Includes hub assemblies
$100
Edelbrock Performer Intake
[ame]http://i34.photobucket.com/albums/d138/WarriorBlaZe/coupe4.jpg[/ame]
$250
Spec Stage 3 Clutch
10 spline
6 puck
Sprung Hub
Low miles
[ame]http://i34.photobucket.com/albums/d138/WarriorBlaZe/Turbo/DSC00123.jpg[/ame]
[ame]http://i34.photobucket.com/albums/d138/WarriorBlaZe/Turbo/DSC00122.jpg[/ame]
$100
I'm sure there is more that I'm forgetting, I'll update this thread later when I think of things.
There is over 10k worth of parts, etc here. I will sell it all for $9,000. Just pick your stand alone, finish the fuel system and a few odds and ends to be up and racing.
Not willing to part anything out other then how I have it listed at this moment.
Thanks for looking.
