Hey guys i thought it was worth trying to ask if my 2000 explorer limited could fit 265/75/16 tires since stock is 255/70/16. Can anybody help me out! thanks guys.
1997 Mustang GT- Sold
MGW short shifter, Ford Racing 3.73s, JLT ram air intake, mach 1 chin spoiler, Off-road H pipe, Magnaflow Magnapacks, SCT X3 tuner, Full PI swap, steeda underdrive pulleys, 75mm throttle body, professional
1999 Mustang Gt- On3performance 70mm single turbo, SCT ba2400 mass air meter, upr tubular k frame, upr front coil overs, 42lb injectors, walbro 255, kenne bell bap, pro 5.0 short shifter, 3.73 gears, Modular Head Shop stage 1 cams, SCT X3 tuner. Waiting on dyno tune!
I'm thinking you should be ok. However, the 265/75 tire will be a little taller than the factory 255/70 tire, so it would throw your speedometer off a little bit ( speedo will read a little slower ). Changing tire circumference also can confuse the ABS - but the change from 255/70 to 265/75 is not that large, so I doubt you'd have a problem. Anyway, those are my guesses - when I replaced the tires on my 2001 Explorer I used the exact same size tire.
Some places like Wal-Mart and Sam's Club will not mount tires that are not exactly the same as the vehicle had when it left the factory. Years ago they'd make you sign a waiver to show that you knew the tire asked them to put on the car was not exactly the same specs as the factory tire - but nowadays they don't do that - at least at the places I've shopped.
Good luck!![]()
Thanks guys
Yea as they have said, you will have no problems with that at all. Your spedo might be off by 1 maybe 2 mph at the most.
03 Cobra=slow show car...
13 F-150 Limited
