3,000 psi with fiber mesh is fine for a driveway or garage floor.
a fairly cheap way of doing a small garage floor with radiant is to use a hot water tank to heat the loops. I've seen it done with large garages but IMHO the time it takes to heat a decent slab plus the cost of energy with a hot water tank doesnt always make sence to me. I like it for a smaller floor though.
^^^ thats a good idea! I was thinking of constructing a passive solar setup to circulate the glycol but that could work too.
my only fear is having a power outage in the middle of winter and the water freezing solid. It typically goes down to -20c at night here (so I guess thats around -4F) in the winter so even a short power outage could cause a freeze.
If you are going to build a garage around it and are going to put the walls on the pad you will need to put in footers around the edge to handle the weight of the walls. and even you aer going to put the walls on the outside of the pad I would sugest putting tin the footers to height and pouring the concrete inside them. This will make the project easier when you get ready to put the walls up.
I agree with the footers comment. I did some more searching and I found that making the footers saves a ton of time. I'm also hitting the library to get some ideas and plans (dialup sucks)
