Results 1 to 12 of 12
Thread: 00 V6 upgrade
    00 V6 upgrade
    Well I was going to build the 95GT i bought, until my hero found a 2000 Mustang V6 and after talking to him over it, i decided to buy it from him and make a nice 90% strip and 10% street car. Well i am finally getting down to this project. Its a V6 car that was wrecked and the guy we got it from lost interest after starting to fix it and got it for a heck of a deal. The first thought that i wanted to do with it was stick to what a i know and put in a good ole pushrod.. And the more re search i do and the more i think about it, the motor i was going to put into it was not going to be worth all the extra work. So after probably about a straight week of doing comparisons and thinking and math and so on and so on, I decided that im going to take a plunge into the mod motors.. Going to be a 4v. Going to build the bottom end using a teskid block and forged crank from a 99/01 cobra and nice rods and pistons.. The top end will be off a 99/01 cobra and same with the wiring and ECU. This is probably the most excited i have been to do a project in a very long time. And im looking forward to learning all i can and do anything i possibly can by myself. Its going to be an all black car or sticking with the redfire paint it has now.. Here are some pics at the beginning of this build
    Me and andy first getting it to the shop and taking a look at everything and taking all the spare parts out of it.
    This is when we got it into the shop and started taking off the interior and drying it out cause the car covers i used when it sat outside did not prevent against rain nor stayed on the car. So i took out the interior and carpet to get underneath and dry everthing out, clean all the dirt and check all the metal so i dont have any surprises on it.
    I am building this car to run in the NMRA mod class (hoping) and the NMCA true street. I have most of the details worked out, but still have alot of things in my head.
    I have most of the front end suspension pieces bought and waiting to be put on..
    AJE K-member and a-arms
    Coilovers
    The car will also have the TKO600 that is still in the yellow car so i can still row through the gears, Once i get the tranny out i will take some pics of that also, but so far what i got for it is a good ole trusty short throw that hopefully will help me out.
    Steeda Tri-ax
    The rear end will be full of 33 Strange spline axles, 33 spline spool, axles tubes welded, 9in ends, 4.10s, Rear end girdle and be built to where it will withstand some big rpm launches
    4.10s
    rear suspension will be from Team Z as well as the rear end work
    never stock biminiLX's Avatar
    Beaver
    2,406
    Nice project Scott!
    Good luck, hope to see you at some of those races.
    Sep 2007
    Dayton PA
    3,795
    looks like a fun project!
    03 Torch Red Anni. Ed. Cobra
    01 cobra: traded
    93 LX Modular 4v swap
    Your off to a good start!
    Whats the plan for the engine?
    Power adder?
    Ditch them heavy steel bumpers & get the tubular pieces they are much lighter!
    Look forward to seeing updates & progress from your build!
    GREEN=FAST sweeney1030's Avatar
    johnstown
    570
    make a tt six they are low compersion and love boost
    Huntingdon, PA
    2,496
    Nice! Good luck with it
    United We 'Stang
    2002 Mineral Grey V6 5-spd
    Good start Scott
    Might want to keep Andy a little further away from it ;)
    robinson
    1,091
    lookiing good. tell andy i will be up for a rematch! he didn't like my tail lights too much lol
    /twocents
    that loooks like a hugh project
    Nice project Scott!
    yea you def will.. I saw you out at columbus but didnt have time to talk but def going to have to get together at a few of these
    thanks
    Power adder?
    The motor will have a built bottom end with a cobra "c" heads, cobra intake and a set of cams.. Planning on a 76 or 80mm turbo probably not as soon as it gets done but in no more than a year.. Yea i will probably have the steel pieces replaced with aluminum since this will not be a DD
    Thanks Rob
    Quote Originally Posted by sweeney1030 View Post
    Im a v8 man. haha
    Quote Originally Posted by no1fordgirl View Post
    Thanks
    Good start Scott
    hahaha..
    Quote Originally Posted by bgblockelcamino View Post
    He dont have a car that will drive down the road except his truck right now
    Quote Originally Posted by vitaleffects626 View Post
    It is, but then again it isnt.. I have most of the pieces that can be put on in a weekend. But im not going to rush this one.
    well family issues have killed this project.. Everything i have for it is for sale if anyone is interested except for the 4.10s and the car itself
  1. Forum Upgrade
    By Wolfpack Speed in forum Site Announcements, Discussion & Help
    Last Post: 07-23-2013, 12:13 PM
  2. gt brake upgrade
    By cemnt guy in forum General Tech
    Last Post: 04-29-2011, 07:50 AM
  3. Ram Upgrade
    By Viper_ed in forum General Tech
    Last Post: 09-03-2010, 12:07 AM
  4. 5.0 upgrade
    By Deuce03 in forum Fox-SN95
    Last Post: 06-18-2009, 08:00 PM
  5. IRS upgrade
    Last Post: 01-23-2007, 01:24 PM
