Well guys ... the front end is D O N E ...
Most of you probably have never seen the issues, but the geometry on a SVO K-Memeber is very different than a normal fox or SN95 car. There is more camber built in, the pick up points are different, and the a-arms are a lot longer. Through a real freakish combination of parts, I got it right where I want it with no more SVO parts up there.
One of the big issues is that using other FOX arms usually moves the wheel back in the wheel well. Part of that is good for me as it gets the tire off the air dam, but with just the arm it would of been too much. Got the Steeda offset bushings in 92 GT arms with TC spindles and it nailed the wheel location ...
Car is filthy right now, but i'm happy with that ....
Now with the coil ovwers and the wheels in 1 1/4" more I could finally drop the nose ...
Down to getting the car on 4 corner scales again and setting pinion agle with all these changes and it's getting done! I will get better pictures once the car is clean and the sun is out :D
