View Poll Results: which tranny?
Voters
75. You may not vote on this poll
  • stick
    56 74.67%
  • slushbox
    19 25.33%
Page 1 of 3 123 LastLast
Results 1 to 20 of 55
Thread: which tranny?
    which tranny?
    i'm in the middle of a new project and can put either style trans in the car , a stick or auto , now the stick would almost have to be either pro shifted or face plated and then the auto would have to have a loose converter and shift hard. which one do you guys prefer and why? oh this will be for mainly drag but with some street time too.
    3,316
    I voted auto because it sounds like you're going to be at the track where consistent, repeatable times are what you need the most and you're doing very little driving where a manual would be an advantage.
    Pro shifting a trans makes driving it on the street real bear. If its going to be mostly a drag, I would say auto. Depending on what power you are looking at. I would go with a TH400.
    But I love rowing the gears on a stick!!!!!
    1,220
    I switched to a C4 for more consistant times at the track. The stick was more fun to drive without a doubt. Like Rob said proshifted and faceplated transmissions are a pain on the street from everything I read when I was deciding what to do.
    What kind of drag racing? You going to run a NMRA class, bracket race, or just be Pro TnT? That's going to go a long way in your decission. There unfortunately is a reality for a lot of combo's where the Auto almost has to come in to play. It really becomes simple economics of a slush box (chick stick?) versus lots of broken shafts, fried clutches, and smashed driveline parts.
    You also have to be honest with yourself if you really are a stick driver. There are people that it comes mostly natural to, others not so much. If it's not in your DNA then it might not be for you ....
    You know my thoughts on this. Beat them with a stick! When I bracket race I am perfectly fine going home early loosing with my stick and still doing it my way. If you have any doubts about stick shift racing, check out some of the UMTR races and see how much fun it can be :D
    Aug 2009
    Ashland, Pa
    230
    well auto is def more consistent a stick is more fun on the street tho, but pro shifting sucks for street and longevity isnt there...
    never stock biminiLX's Avatar
    Beaver
    2,406
    How much power and RPM? What type of tires?
    Dec 2008
    Natrona Heights PA
    3,056
    "Real Race Cars Have A Clutch"!!!!! lol
    Bu-2000-bash
    ALLSQUAD
    Steel City Muscle Cars
    CarCruises
    Flashlight Drags
    NMRA
    UMTR
    Modded Mustangs
    NHSCC
    its going to be a 351 based motor so around 7k for rpm. the car will be mini tubed and i'm not sure on a tire yet maybe a drag radial ?
    Beaver
    2,406
    Hmm, tough call then. I've done the 427" both NA (6500rpm shift) and turbo (6000rpm shift) with a stick and its doable, but like Bob said, if you value more consistency and drag performance over street use and fun then auto, if the other way around stick.
    So does any of this mean you have made a decission yet??
    Beaver
    2,406
    Yeah :( bummer, now debating PG or built custom AOD (2.20 first, several in the 8s).
    light 'em up! 2005mach1's Avatar
    greensburg area
    84
    well being that its for drag i would say auto
    B*tch I dont care, I'm made outta LAFFY TAFFY!!
    http://www.madwhips.com/modified-mac...trufiber-hood/
    Troy - we run one of these in the chevelle - clutch assisted with h pattern shifter http://www.gforcetransmissions.com/tran_gf5r.asp
    No synchro's, dog ring type trans - good to 1300hp in a 3800lb car.
    It is PLENTY streetable, despite many who told us it was too much for the street. Don't get me wrong, it whines pretty loudly in all gears except 5th (5th is 1:1, no overdrive). It's easy to upshift, with an occasional clunk. Downshifting requires slightly more skill/effort, but as soon as you get the hang of it with a little blip of the throttle, it's no big thing. You can RIP gears with this thing at full throttle too - it's a monster. I've never driven a faceplated tko or anything, but people tell me the gf5r is more street friendly.
    We put 800 miles on the car last year with this trans, and I wouldn't hesitate to drive it anywhere, even highway. You can't put an overdrive in it though, so we adjusted rear end ratios and tranny ratios to have 5th gear act like an overdrive (3.42 first gear with 3.00:1 rear end gears).
    Downside - the trans wasn't cheap! G-force customer service is unparalled though - they're awesome, so that makes up for it in my book, in addition to them building a killer transmission. Plus, no special bell housing or clutch is needed.
    If you want more info, let me know!
    Mt Pleasant, PA
    4,905
    This is all you Troy. Smoking deal if you ask me.
    http://modularmisfits.com/forums/showthread.php?t=494
    thanks guys some more info on the combo, i am trying to get the car down to 2650 lbs to help it be a little easier on parts.
    hmmm ... I thought it would be a TH400 and be done with it ;) Besdies sucking on the street, I bet your car would love a glide.... loooooonggggg gears for lots of load :D
    a pg has crossed my mind too they help with traction too with a taller first gear , i just think its not a race car with out 3 pedals though....
    Petersburg,PA. 16669
    816
    unless you are making well over a 1000 hp you don't want a glide nor a TH400. A TH400 is a big trans that takes lots of power to run.A PA C$ guaranteed for life is the only way to go there and they will live well under high hp applications and when they start to slip fix it for free.
    Troy, Steve still has the faceplated G Force in the car and weather permitting if you come get those doors he will take you a ride and trust me it's one you won't soon forget especially with all the boost and frying tire crusin in 4th gear at 80 mph
    88 GT...and some boost
    ok sounds good i'll look forward to a ride ,i will try and make it down this week weather permiting
  1. tranny
    By 89lx 5.0HO in forum Ford Parts
    Last Post: 07-30-2010, 10:00 AM
  2. My tranny
    By 89lx 5.0HO in forum General Tech
    Last Post: 07-27-2010, 06:26 PM
  3. Tranny!!!!!!!!!!!
    Last Post: 05-27-2010, 09:35 AM
  4. Replies: 0
    Last Post: 02-28-2009, 11:52 AM
  5. how do i know what tranny i have
    By pwtmxracing in forum General Tech
    Last Post: 12-26-2007, 09:54 PM
