Results 1 to 11 of 11
Thread: Compression Ratio
    1,035
    Compression Ratio
    What is the consensus for compression ratios on a supercharged motor.
    For example if you had a 02 GT with a Centrifugal blower making 12-15 PSI. What would those with buiding experience spec out the CR at?
    2016 Mustang GT
    i would keep it to around 9.0-1 is there an intercooler involved ?
    Troy, from the little I know about mod motors, I'm pretty sure they can tollerate higher compression ratios than pushrod engines typically can due to a more efficient combustion chamber. Since I have never built nor owned one I will not offer a recommendation.
    Burntire, what octane is available to you out there? It may help those that have actually built mod motors help with a recommendation.
    1,035
    We have 91 octane with sand in it. LOL
    Yes the application would be intercooled. Procharger P1-SC
    2016 Mustang GT
    Spencerport, NY
    3,762
    I would say between 9.0:1 and 9.5:1 ...
    I think its a worthwhile tradeoff to feel safe from detonation, and just add a little extra boost... plus some sort of intercooling or water/meth cooling helps bring ease to the mind...
    2015 Corvette Z06
    - Shark Grey / Kalahari
    fairmont,WV
    1,352
    whats the main purpose of the car? street, strip or both...this will help
    XXX RWHP
    XXX RWTQ
    never stock biminiLX's Avatar
    Beaver
    2,406
    Paul, there's an 1100hp 10:1 5.4 4V/3.6 KB build in the new 5.0 mag, Milhovetz (who knows how to build a mod motor) said the 4V combustion chamber can tolerate the higher compression, no mention of the 2V.
    If this is a pump gas street motor you plan to put miles on, I'd think you'd be safer staying around 9-9.5:1. No reason to push it IMO.
    1,035
    Primarily street.
    2016 Mustang GT
    Higher elevation can tolerate higher C/R.
    From what I am finding most say keep it above 9.0:1 for street use.
    fairmont,WV
    1,352
    me personally, i wouldnt go past 9:1...w/ that level of boost your cylinder pressure will be really high and im not sure if 91 octane will support it.
    XXX RWHP
    XXX RWTQ
  1. For Sale: Used 4.30 ratio 8.8 gears.
    Last Post: 05-20-2010, 05:42 PM
  2. 1.6 ratio,7/16" stud mount roller rockers
    Last Post: 04-01-2010, 10:36 PM
  3. gear ratio ????
    Last Post: 07-14-2009, 09:24 PM
  4. Everyone with wideband's... what is your cruising AF ratio?
    By Killercanary in forum General Tech
    Last Post: 08-04-2008, 11:54 PM
