i have patriot 185cc aluminum heads. nothing on this motor is stock
42's still good
wanna go 60's go ahead but you will need a tune for sure or a tuning device because 60's won't run off the stock ecu without help.Still don't see but 400 rwhp and 42's are plenty for that
88 GT...and some boost
Post 3 says he is getting it tuned. Do 60's and dont look back. I made the mistake of running 44's and wont ever do that again. Your car, your choice. Good luck.
my main concern is doing the right maf and yes it willbe getting tuned before its even driven. with a modded motor and 10 to 12lbs what type of numbers will i see? any estimate?
Depends on the mods. You could get over 500. A buddy of mine with a stock block put out 606 on the rollers. He has a T-trim though.
With a stock headed motor and a SysteMax II intake, 95mm velocity meter I made 397.66/397.77@ 5200. Added a set of twisted wedges and got 48? @ 4500. You can make power, just select a good combo. I already told you what works well. Consider if you are going to do the intercooler now or later and how much later. That should be your deciding factor in the meter. I believe I already mentioned the Pmas 95mm velocity. I had one and it was great. My second tuner said it was off calibration by 20% but didnt really matter. He fixed that in the tune.
ur bud who laid 606 his name isnt winkler is it, red 93 cobra???
606! wonder what it will do in a lighter car??
ya he lives down the road from me. silver notch i love the car i used 2 c urs at shows and wanted one just couldnt find one so went with a gt
now i have a way nicer blue gt not the gray one. maybe now i wont feel bad parking near u guys. also im good friends with shipleys, believe u know them??
I dont know if I know shipleys or not. I met a good bit of folks knowing silvernotch. You have probably seen my car then if you see silvernotch at cruises. I am usually with him along with the others.
what are u driving Wick?? and i know silver notch and winkler know the ships. i think they are cousins?? who knows
The red GT with the blower whine. Cant miss it. Polished '99 cobra wheels. Almost always have my son with me.
yea i saw the red 93 doing a burnout on thanksgiving when i was painting my stang its def badass
is it dark red? if it is and uve been to shows around here most likely ive seen it
