Since it's gone i need this stuff outta here. New 16x10 AR Baja's with almost new ET Streets. Long story short, bought the rims new and a set of nearly new Et's from a member here , but got screwed. When I went to get the tires mounted they found the inner sidewall of one was chewed up from rubbing a bolt on this guys Cobra ( of course this was the tire he made sure to load for me and i'm to trusting to examine things like I'm buying from the devil. Thanks a$$hole). So anyway this size tire is discontinued so the rims have one 28x12.5x16 and one 28x11.5x16. Same diameter ones just narrower. Also includes the open ended acorn nuts to use the rims. Want 250. Also have an autometer column pod with an autometer boost gauge. I dropped the gauge (duh) and it bent the lip a little as you can see in the pic. Looking for 30. Thanks.
