Results 1 to 5 of 5
Thread: foxbody front coil cutting
    NEWB delldoe's Avatar
    Mill Creek, PA
    66
    Here is a short picture gallery of cutting the stock springs on my 92 GT to lower the ride height. We removed 3/4 coil off the bottom of the factory front springs. The results are as follows. On a side note, we didn't have the correct spring compressor so we used the wrong one then used safety wire to hold the springs compressed while installing... DO NOT DO THIS... You will die.
    TOOLS FOR THE JOB:
    Jack
    Jackstands
    Hacksaw/sawsall (find something to cut them with but dont use heat)
    Time
    Correct Spring Compressor (which we did not have) Correct spring compressor should be installed inside the spring.
    Common Sense (which we totally ignored and completed task anyhow)
    Beer
    Functional socket set
    Dewalt Impact
    WD-40
    BEFORE:
    AFTER:
    1992 Mustang GT
    2005 GSXR 750
    2002 HD softail duece
    Castle Shannon
    1,276
    mmm... iced animal cookies are great munchie foodz. :P
    did the same thing to a 99 no spring compressor so i used a rachet strap
    ur car looks good tho
    Mustang 00 v6- Mini Termi
    Mustang 94 v6-sold
    Mustang 93-sold
    Mustang 86 notch 2.3-sold
    plum
    487
    Cool, looks much better!
    Huntingdon PA
    1,136
    garage looks familiar
    709RWHP/750RWTQ
  1. Need 99-04 front coil springs
    By orangemachine in forum Ford Parts
    Last Post: 05-03-2011, 06:51 AM
  2. FS:front coil over kit
    Last Post: 01-07-2011, 07:26 PM
  3. front coil over setup
    Last Post: 01-05-2011, 07:32 AM
  4. For Sale: Front coil over kit- 79 - 04
    Last Post: 10-27-2010, 09:56 AM
  5. Front coil overs
    By fast4ord in forum Fox-SN95
    Last Post: 02-06-2007, 12:03 AM
