Results 1 to 6 of 6
Thread: 95 GT key ignition problem
    Gibsonia, PA
    323
    Guys,
    I have the situation where the black rotating assembly of my steering column key ignition gets out-of-sync with the key when you start or turn off the ignition.
    I have to hold the key and the black outer rotating assembly together to keep them aligned.
    And if not, the key gets all jammed in there and it is a PITA to get it out.
    Anyone familiar with this?
    How to fix?
    My friend told me that you could shove a center punch up through a hole in the steering column and pop that whole ignition switch out and get a new one from a locksmith keyed to fit. Is that true? Does anyone know of a place who can do this for me?
    Thanks!
    Mine has done this for a long time and its a fairly common problem. I'm just careful with it. I never looked into a fix for it though. I just make sure sure to turn them both at the same time when I start it/shut it off.
    Senior Member TJH64's Avatar
    Delmont PA
    320
    Mine did this also, but I replaced it. I couldn't find one specific for our cars at the auto parts, so it was ordered through Ford-about $30 IIRC. It was easy to remove, put the key in the ignition and turn it to the accessory position. Insert an awl, or any other small pointed tool into a hole on the lower side of the ignition housing, and pull the switch out.
    I never got my ignition key cut to match the existing, I just got different keys for the ignition and locks-no big deal.
    Sep 2007
    Dayton PA
    3,795
    the yellow 95 I bought was like that, but it was missing the key so i got the tumbler and everything to fix the problem, i put a 96+ key and tumbler in it.
    03 Torch Red Anni. Ed. Cobra
    01 cobra: traded
    93 LX Modular 4v swap
    1,220
    If you take your key to a Ford dealer they should be able to code the new lock cylinder to your key.
    Gibsonia, PA
    323
    Thanks guys!
    This thing is a PITA so I think I am going to try and fix it soon.
  1. Track Key for Mustang GT
    By juice_man_86 in forum The Bar
    Last Post: 05-29-2014, 01:07 PM
  2. Hilter vs Track key
    By 2000GT in forum Pictures & Videos
    Last Post: 09-25-2011, 08:46 PM
  3. key fob
    By 94gt5.0 in forum Ford Parts
    Last Post: 02-05-2010, 08:38 PM
  4. 88 steering colum with key
    Last Post: 05-17-2009, 08:01 PM
  5. Door Key?
    By Stangman701 in forum The Bar
    Last Post: 03-10-2009, 09:56 PM
