Results 1 to 10 of 10
Thread: 347 Stroker Mexican Shortblock
Hybrid View
    Built professionally by FordStrokers.com ( www.FordStrokers.com )
    Probe forged SRS 14.2cc dish 4.030 pistons
    Probe cnc beam 5.315 connecting rods
    Probe Cast Steel 3.400 Stroke Crank
    Camshaft Innovations Custom Billet Camshaft
    Competition Cams Adjustable Billet Timing Set – 7138
    ARP Pro Series Cylinder Head Studs - ARP 154-4201
    Professional Products SFI Harmonic Damper Balancer 28 oz. - PFS-90006
    Melling M-68 Standard-Volume Oil-Pump (Blue-Printed by FordStrokers.com)
    ARP main studs, ARP oil pump driveshaft, Total Seal Rings & King Bearings
    Trick Flow Specialties Head Locating Dowels - TFS-51400420
    Canton 15-620-S Oil Pan w/ Pickup & Dipstick.
    Compression ratios as follows according to your heads:
    58.0cc – 9.84
    61.0cc – 9.52
    64.0cc – 9.22
    68.0cc – 8.86
    This short block is only being sold due to the fact that I’m upgrading to a race-spec short block. The engine has only been started 3 different times and has only been at an idle (1000rpm). Total run time is probably 30-40 minutes at an idle (1000rpm). At idle the engine holds 50 psi of oil pressure with Valvoline 10W30 as can be seen in the video below.
    The Camshaft is a Custom Billet Core Cam that I had Camshaft Innovation make for this engine (cam specs to buyer). This engine is 100% ready to go and is currently in my car and can be seen and heard at buyer’s request.
    You will be getting a complete short block from head studs, cam, timing chain, balancer, Head Locating Dowels, Blue-Printed Oil-Pump, Camshaft Degreed, Oil-Pan has blower oil drain-back fitting that can be capped off if not used. The video taken below is with just straight open headers thus being very loud! This engine can be ran N/A or with a Power Adder as the compression is at a happy-medium between the two depending on the cc of the heads you will be using.
    Any questions please PM or email me at rnshuble@yahoo.com
    Engine is located in Weirton, WV (20minutes from Robinson, PA). To duplicate this exact engine with the exact parts I used will cost in excess of $3500. This engine is Brand New and ready to make somebody’s ride super fast.
    Price is: $2650
    I tried to edit this and it wont work. So here's the edit:
    Should read: Probe CNC I Beam 5.315 Connecting Rods
    And Cam is a TLSR (Tight Lash Solid Roller) Cam by Camshaft Innovations
    This can be a nice power adder shortblock or add some heads that have been milled down to 55-56cc and you can have a nice N/A 10.0:1 Compression engine that will easily make 400+ rwhp with a nice set of heads.
    Senior Member TJH64's Avatar
    Delmont PA
    320
    Wow, Rob. Not to hijack the thread, but what are you upgrading to?
    Dart 363.......
    Possibly a Dart 371
    Delmont PA
    320
    Dart 363.......
    Possibly a Dart 371
    SWEET
    You looking to drop your ET's more than the 347 would have run?
    SWEET
    Yes, this will be a bottom 10 second N/A engine.
  1. 347 Stroker
    Last Post: 10-25-2011, 10:05 PM
  2. Gmkillr's Mexican 347 build
    By gmkillr in forum Pictures & Videos
    Last Post: 02-05-2010, 08:24 PM
  3. FOR SALE!Mexican 347 shortblock&dry nitrous kit!
    By thebreeze72 in forum For Sale
    Last Post: 04-25-2009, 03:10 AM
  4. 347 stroker
    By went9s in forum For Sale
    Last Post: 11-24-2007, 01:08 PM
  5. 347 Stroker in PA
    Last Post: 11-03-2007, 07:57 PM
