Results 1 to 2 of 2
Thread: Moser 35 spline axles, spool, and brake brackets.
    Yellow is faster!
    York PA
    273
    Moser 35 spline gun drilled and star flanged axles.
    C-clip eliminators will go with the axles.
    5/8" studs, bushings and lug nuts are included.
    Axles are 99-04 length.
    I was told there are only 10-12 passes on these axles.
    $350 (~$800 new)
    Moser 35 spline lightweight spool, with 8.8 bearings. Part number on spool is ME88F3530
    Same amount of run time as the above axles.
    $150
    Also have a set of brake brakets for a dual caliper setup. Not sure of the manufacture and I can measure the bolt patern to see if they will work for you. They will work with an 8.8 and c-clip eliminators.
    $40
    Jason
    Just a little stock coyote that runs low 10s!
    Yellow is faster!
    York PA
    273
    Update with new stuff: (brake brackets sold)
    28 spline trac lok with good clutches
    $35
    8.8 4.10 gears. No stamping so they are not FMS. There is a surface where the phosphate is removed and there are numbers vibr-a-tooled onto the head of the gear and also on the ring gear. I had a set of richmonds a while back that looked similar. Good wear pattern!
    $80
    Ford 3.27 gears in good condition and good wear pattern
    $35
    Jason
  1. Replies: 7
    Last Post: 03-04-2014, 01:41 PM
  2. Moser 31 spline "C" clip 5 lug axles for sale
    By gmslayer in forum Ford Vehicles
    Last Post: 08-10-2013, 09:16 PM
  3. FS: 99-04 Mustang GT / V6 28 Spline Moser Axles
    Last Post: 05-05-2011, 11:54 AM
  4. New Moser 31 Spline Axles for 99-04 8.8s. Save Money!
    By 01CAMMER in forum Ford Vehicles
    Last Post: 07-11-2010, 01:17 PM
  5. Moser, 28 spline, 5 lug FOX axles
    Last Post: 04-09-2010, 08:31 PM
