Results 1 to 5 of 5
Thread: spark plugs
    Senior Member ebo 4356's Avatar
    Sep 2008
    California, Pa
    194
    spark plugs
    I changed my spark plugs the other day, and put motorcraft SP 493 in. I finally was able to get the car out today and its missing at low rpms, the gap on the new plugs were at .54 and my old motorcrafts had a gap of .65 and they call for .54 so i dont what to do now.
    1997 Mustang GT- Sold
    MGW short shifter, Ford Racing 3.73s, JLT ram air intake, mach 1 chin spoiler, Off-road H pipe, Magnaflow Magnapacks, SCT X3 tuner, Full PI swap, steeda underdrive pulleys, 75mm throttle body, professional
    1999 Mustang Gt- On3performance 70mm single turbo, SCT ba2400 mass air meter, upr tubular k frame, upr front coil overs, 42lb injectors, walbro 255, kenne bell bap, pro 5.0 short shifter, 3.73 gears, Modular Head Shop stage 1 cams, SCT X3 tuner. Waiting on dyno tune!
    sounds really stupid but check make sure all urs wires are snapped on the hole way
    Mustang 00 v6- Mini Termi
    Mustang 94 v6-sold
    Mustang 93-sold
    Mustang 86 notch 2.3-sold
    Belle Vernon
    1,294
    Quote Originally Posted by 93FOX View Post
    X2 and make sure you didnt mix any wires up. Its possible to get a bad plug.
    '89 Mustang GT
    '04.5 Duramax
    Jones Race Car Trailers
    www.jonesrv.com
    Polar Vortex
    6,031
    if you never removed the wires from the coil packs, you can easily trace the wire to see if they're going to the right plug. The cylinder numbers should be in accending order from the front or back of the engine. You should figure it out..
    Sep 2008
    California, Pa
    194
    I figured it out, one of the spark plug wire boot was ripped.
  1. 03 cobra spark plugs
    By 92306gt in forum SN95-New Edge
    Last Post: 01-23-2013, 09:20 PM
  2. Spark Plugs
    Last Post: 07-28-2008, 05:53 PM
  3. reccomended spark plugs
    By stangfever in forum General Tech
    Last Post: 04-28-2008, 09:30 PM
  4. N20 Spark Plugs
    Last Post: 05-27-2007, 12:48 PM
