Results 1 to 2 of 2
Thread: cooling fans
    plum
    487
    cooling fans
    I have 2 cooling fans for sale. Both are electric. 1 is a Tuarus fan that is in great shape, complete with the shroud and brackets to mount to a 5.0. the other is a aftermarket unit that can be installed in a stock 5.0 shroud or mounted to your rad directly. $35.00 per fan, both are in great working condition. Thanks, Jason 412 983 3546
    plum
    487
    bump
  1. Cooling fan died
    By speedracer in forum SN95-New Edge
    Last Post: 10-21-2012, 12:32 AM
  2. elect cooling fans and mount kit
    Last Post: 09-09-2012, 12:36 PM
  3. Please help! Cooling fan not working
    By 1LOUDSVT in forum SN95-New Edge
    Last Post: 08-06-2009, 04:54 PM
  4. I need some help diagnosing a cooling problem
    By DRRummel in forum Fox-SN95
    Last Post: 04-03-2009, 12:23 PM
  5. SN 95 cooling question
    By wick in forum General Tech
    Last Post: 05-31-2008, 05:41 PM
