Results 1 to 15 of 15
Thread: difference in linear and progressive springs
    Farmington WV
    4,672
    http://www.stangsuspension.com/store...tesarticle.asp
    so i was checking out different spring rates and comparing the FMS to stock mach 1 and bullitts and noticed the main difference in mach 1 and FMS C's is the rear in the mach is linear and rear in C's are progressive.
    so whats the difference on the street? looks like the mach 1 and C's would be very comparible for a street car.
    edit #2 - the lower the number the softer the spring? or vice versa
    shaler,pa
    1,010
    You raising your car to stock height Jared?
    Farmington WV
    4,672
    no...the front is higher than the rear. and i want it leveled out. i have always liked the FMS C springs and was looking at the spring rates and see the Mach 1's are very close to C's
    i saw wicks stang with the B springs and it looked really good...so i think the C's will tuck 17" rims a little more...plus look better while im on 16's.
    Here is a picture of the FMS C springs on my 88 before they were taken off. I think the give just the right stance for 17" rims.
    Farmington WV
    4,672
    i agree completely....now if i was to go with the Mach 1's....how would the rear compare. since one is linear and one is progressive.
    also Ed - did you cut your C's or remove isolators or anything? thats the look im after
    Didn't do a thing to them, just bolted them in.
    Farmington WV
    4,672
    so what about linear vs progressive.
    I'll wait and let Pure Stock write you a book on it. He's one of the better ones on this site to answer suspension questions.
    Farmington WV
    4,672
    Farmington WV
    4,672
    ed - did you leave your isolators in? i know by installing aftermarket control arms in the rear it lowers it a bit too. i was going to leave the front isolators out to try and level it.
    i did this to my old 95
    I think I did, but It's been so long, I can't say for sure till I take them out.
    Farmington WV
    4,672
    ill just check on sunday. LOL
    Member Knapper411's Avatar
    Cape Cod
    27
    Linear springs and progressive springs arent any different in height. They are as tall as they say they are. The difference is linear springs take a certain weight to move the spring one inch and the same amount of weight ontop of that to compress another inch.
    Progressives just take more weight to compress them per inch, like 100 pounds the first inch n 150 ontop of that for the second inch.
    Leaf springs are considered a progressive rate spring.
    I dont care if it circles the world 11 times in 1 second. If its front wheel drive, its worthless.
    3,356
    Progressive springs are supposed to have a softer rate upon initial normal travel and get stiffer as coils are compressed.
    Linear are just as stiff all the way thru their travel.
    Mark
    LeMans Blue Z06
    Cape Cod
    27
    The rate would be as advertized, there not any more soft than they should be. Its how their manufactured.
  1. cold fusion digital progressive nitrous controller
    Last Post: 11-20-2014, 03:24 PM
  2. Steeda Progressive Rate front coil springs
    By orangemachine in forum Ford Vehicles
    Last Post: 05-06-2011, 10:11 PM
  3. Replies: 8
    Last Post: 11-18-2007, 01:16 AM
  4. lowering springs ford racing c springs like new
    Last Post: 10-22-2007, 02:38 PM
  5. difference in GT40 heads
    By J-rod in forum Fox-SN95
    Last Post: 04-02-2007, 12:02 AM
