Results 1 to 3 of 3
Thread: trick flow intake??
    NEWB 89stang's Avatar
    North Huntingdon
    1,136
    trick flow intake??
    What is the difference between the streeheat intake and track?
    Petersburg,PA. 16669
    816
    track heat plenum is 1" shorter in length and is good to 6500 instead of 5500
    stock heads use the street heat
    88 GT...and some boost
    Under PSI Black Vert's Avatar
    Cranberry Twp.
    344
    Looks like the trackheat has a higher rpm operating range and no egr port. Less bottom end torque for the street.
  1. FS: Trick Flow R Intake
    Last Post: 03-15-2013, 09:06 PM
  2. Trick Flow Intake
    By 1slow46 in forum Ford Vehicles
    Last Post: 02-08-2010, 08:05 PM
  3. Trick Flow Intake
    By CESCO in forum Ford Parts
    Last Post: 01-11-2010, 10:01 AM
  4. Trick Flow intake
    Last Post: 05-09-2008, 07:01 PM
  5. trick flow r intake
    By urgonnaluz2me in forum Ford Vehicles
    Last Post: 03-27-2007, 07:28 PM
