Results 1 to 7 of 7
Thread: What is the proper fuel pressure
    Senior Member Cam99's Avatar
    Melcroft
    4,178
    Finally got around to hooking up my Autometer fuel pressure gauge and was wondering what the proper pressure should be. It hovers around 29lbs at idle and goes up to 45+ when i rev it. Don't have insurance back on it yet so I don't know what it does under load. Seem normal?
    shaler,pa
    1,010
    Did you have the car tuned anywhere?
    Sounds pretty ballpark to me, which gauge did you get, the one that mounts in the car? Or the underhood one?
    Melcroft
    4,178
    Kauffman's. My car also has the Focus pump. This was on the motor tune not the n20 tune, didn't think to switch it to see if there is a difference.
    Melcroft
    4,178
    It's the one that mounts in the car. I actually mounted the sensor in a block right before the Zex controller box because I figured that would give me a good indication of what my pressure is doing when the nitrous is activated ( wet kit)
    Melcroft
    4,178
    Road tested tonight. WOT it hovers around 38ish PSi. Seems a little low to me?
    Yes, that does sound kinda low, you better investigate to see what the problem is.
    Good luck!
  1. Fuel Pressure Regulator Questions
    By Stangman701 in forum SN95-New Edge
    Last Post: 07-12-2012, 09:50 AM
  2. question on fuel pressure
    By vitaleffects626 in forum General Tech
    Last Post: 05-05-2011, 10:04 PM
  3. stock fuel pressure
    By JETHRO in forum Fox-SN95
    Last Post: 03-14-2008, 06:29 PM
  4. Fuel pressure gauge question
    Last Post: 10-23-2007, 04:17 PM
  5. Fuel Pressure
    By coralcoupe1993 in forum General Tech
    Last Post: 09-30-2007, 06:46 PM
