Page 1 of 5 123 ... LastLast
Results 1 to 20 of 82
Thread: 416 LS3 Build - Part 2 - I Love You Bo :)
    If You Wanna thedak's Avatar
    Jul 2008
    DMB
    Got everything back from the machine shop.
    Had the Diamond Pistons coated by Calico
    CT-2 Thermal Barrier Coating - Piston tops
    CT-3 Dry Film Lubricating Coating - Piston Skirts
    Bearings are also coated by Calico
    CT-1 Dry Film Lubricating Coating - Bearings
    Mic the pistons and check piston/cylinder clearance.
    The piston manufacturer (Diamonds, in this instance) specifies precisely where you are to measure piston diameter, and also the required piston/cylinder clearance.
    Here we are measuring .850 down from the oil ring on the skirt, 90 degrees from the pin:
    All 8 pistons came in at 4.058
    .0055, just what Diamond specified
    Jul 2008
    DMB
    Checking the size of the main bearing bores:
    Upper halves of main bearings in place
    Main caps back on with other halves of main bearings:
    Jul 2008
    DMB
    mic'ing the crank
    This image has been resized. Click this bar to view the full image. The original image is sized 1024x766 and weights 159KB.
    it was dead on @2.559"
    This image has been resized. Click this bar to view the full image. The original image is sized 1024x768 and weights 140KB.
    checking the main bores, bearings in place, caps torqued, with dial bore gauge
    This image has been resized. Click this bar to view the full image. The original image is sized 1024x766 and weights 201KB.
    close to .0025, a little loose
    Machine shop is redoing the align hone and the bearings are out to coating.
    Looking for a main bearing clearance of .0015" - .0018"
    This image has been resized. Click this bar to view the full image. The original image is sized 1024x766 and weights 96KB.
    Jul 2008
    DMB
    Mic'd all the rod journals of the Callies crank:
    This image has been resized. Click this bar to view the full image. The original image is sized 1024x768 and weights 212KB.
    2.0991.......ALL of them...this is a very nice piece
    This image has been resized. Click this bar to view the full image. The original image is sized 1024x768 and weights 237KB.
    Checked the big ends of the Callies rods. Very nice. All within spec. Actually they were all the very same dimension. I am very impressed with this Callies stuff.
    Next I checked 2 of the rods, torqued, with rod bearings in them, with the dial bore indicator. Appears we have .0017 rod bearing clearance. I took the mic that I used to mic the rod journals and these 2 rods to the machinist to double check. Yep, .0017 rod bearing clearance.
    Decided to check them with Plastigage as well
    This image has been resized. Click this bar to view the full image. The original image is sized 1024x768 and weights 261KB.
    Jul 2008
    DMB
    Bridge and dial indicator to check the deck height(s):
    This image has been resized. Click this bar to view the full image. The original image is sized 873x1023 and weights 308KB.
    This image has been resized. Click this bar to view the full image. The original image is sized 1024x766 and weights 343KB.
    Block will be relieved slightly at the bottom of each cylinder where the rod bolt comes close:
    This image has been resized. Click this bar to view the full image. The original image is sized 1024x768 and weights 304KB.
    So the block is back at the machine shop now for decking. We are shooting for an average of about -.011.
    With a compressed head gasket thickness of .051, that will put the quench at around .040.
    SCR - 11.56:1
    Nice work there. Great way to be thorough. When are you looking to having this thing running?
    Jul 2008
    DMB
    Sometime in March
    Good deal. Whatcha looking to get out of it? Trying to start mine by my birthday next week.
    Aug 2008
    State College PA
    2,326
    I can't wait to hear all about this "GM" build at my next dentist appointment! How appropriate, mouth pain and GM motor talk!! ...
    J/K looks pretty interesting. Maybe I'll get an invite from the Dr to watch while you guys build??
    PICS & Dyno
    Figured somebody would start the GM shit again. Who cares. Its an interesting build. Lets keep this one on topic and clean. Please!!!!!!!!
    Aug 2008
    State College PA
    2,326
    Dude relax he knows I'm only busting his chops ...
    PICS & Dyno
    Quote Originally Posted by mr4teth View Post
    Yeah, thats what happened in the last thread that became closed. Remember?
    Aug 2008
    State College PA
    2,326
    With a thread topic like this do you think my inside joke with LS2GTO is going to spark the "heat"? ... NO
    PICS & Dyno
    Give it time, I'm done.
    Jul 2008
    DMB
    Gregg knows his shit.
    I haved learned a lot from him and this build.
    BtW,
    I'll let you hold the work light.
    Aug 2008
    State College PA
    2,326
    Quote Originally Posted by LS2GTO View Post
    BtW,
    That's probably beyond my skill level. I'm pretty good at picking up dropped tools, bolts, nuts and holding beers .... that's about it!
    Yep Gregg is like Rain-man when it comes to motors! Half the time he's talking I'm completely lost .. not hard to do BTW.
    PICS & Dyno
    mic'ing the crank
    Why not get the bearings coated and THEN check the clearance to see where you're at......instead of getting the bearings coated AND the block cut at the same time.
    Or...
    Get some .001 oversize brgs to bring you to .0015 and call it a day.
    Jul 2008
    DMB
    Or...
    I could easily do a .001+ bearing an be done.
    I 100% want my bearings coated.
    The main bores were 2.752" Spec is 2.750"
    Redoing the align hone will give me a little more crush as well.
    The coating thickness is only ~.00025"
    I ASSume by the marks on the deck, you have checked all 8 holes, 4 places for deck height off the piston? If i'm reading the number right they look pretty close. Why I ask, several of the 2.3 crowd have had issues with Diamond pistons being up to .010 out of parallel to the deck and Diamond reports that as their tolerance. Your look close ...
    Jul 2008
    DMB
    We were real happy with the Diamonds.
    The only piston that was slightly different was the reluctor wheel piston.
    It sat in the hole about .002" more than the rest. Not to bad.
    The assembly and block was fairly square as well.
    Decking .010 off one side and .008 off the other.
  1. Sound clip of my LS3 with ZO6 exhaust & Borla Stinger!
    By gmkillr in forum Pictures & Videos
    Last Post: 04-01-2013, 09:07 PM
  2. LS3 mustang
    By 92306gt in forum The Bar
    Last Post: 04-20-2011, 11:08 AM
  3. Build AOD vs. Build C4
    By roush08 in forum Fox-SN95
    Last Post: 01-27-2011, 08:13 AM
  4. 416ci - LS3 Build
    By thedak in forum General Tech
    Last Post: 11-29-2009, 08:41 PM
  5. Got the go part down, now to work on the stop part.
    By fx-man in forum General Tech
    Last Post: 05-29-2007, 09:55 AM
