Glad ta see its comin along well. Ur pretty much talkin in another language thou, lol! Keep us posted, maybe I can learn a bit. Since um so illiterate when it comes to engine talk n #'ers.
Bu-2000-bash
ALLSQUAD
Steel City Muscle Cars
CarCruises
Flashlight Drags
NMRA
UMTR
Modded Mustangs
NHSCC
These are a -2cc flat top piston made for L92 and LS3 heads.
Subscribing for results, good shit so far.
Looking good. Can't wait to see this thing done!
Very nice.... good luck finishing it up!
2015 Corvette Z06
- Shark Grey / Kalahari
You are on a different page...
Just because the main bore is reduced by .001 doesn't mean you bearing clearance will be reduced the same amount.
It may not change the bearing clearance at all. The bearing is just going to have more crush on it.
Not to mention the coating will actually reduce the bearing clearance by twice that amount as both the top and bottom bearing are coated.
yep...late-night mental block.
I guess you'll have to get the align hone redone and then see what the actual numbers are.....
I don't think you're going to get away with reducing the crank journal in the block by .002 and not changing the clearance, unless there is currently no bearing crush at all.
awesome build.. glad to see this came back..
good luck and keep us posted.. Still sticking na?
Got the intake set up and ready to go.
FAST 57 pounders were used.
That intake is sick!!
F.A.S.T are easily the best intakes on the market for a lsx car
Got the block back after decking and re-checking the main bearing bores:
This image has been resized. Click this bar to view the full image. The original image is sized 1024x766 and weights 283KB.
Had to do a little clearancing where the stroker crank brings the rod bolt close to the bottom of the cylinder:
This image has been resized. Click this bar to view the full image. The original image is sized 1024x768 and weights 317KB.
Time to adjust the end gaps of the rings
This image has been resized. Click this bar to view the full image. The original image is sized 1024x766 and weights 279KB.
This image has been resized. Click this bar to view the full image. The original image is sized 1024x766 and weights 268KB.
Specified end gaps:
This image has been resized. Click this bar to view the full image. The original image is sized 1023x362 and weights 206KB.
Since the bore is 4.0635, we'll set the gap for the tops rings at 4.0635 x .0045 = .018"
This image has been resized. Click this bar to view the full image. The original image is sized 1024x768 and weights 167KB.
Using a ring seating tool to seat the top rings in the cylinders:
This image has been resized. Click this bar to view the full image. The original image is sized 1024x766 and weights 295KB.
This image has been resized. Click this bar to view the full image. The original image is sized 1024x766 and weights 252KB.
This image has been resized. Click this bar to view the full image. The original image is sized 1024x766 and weights 259KB.
The feeler gauge will not pass. The gaps are smaller than .018":
This image has been resized. Click this bar to view the full image. The original image is sized 1024x768 and weights 183KB.
This image has been resized. Click this bar to view the full image. The original image is sized 1024x768 and weights 242KB.
End gap adjusted, the feeler gauge now passes:
This image has been resized. Click this bar to view the full image. The original image is sized 1024x768 and weights 234KB.
This image has been resized. Click this bar to view the full image. The original image is sized 1024x768 and weights 223KB.
The 2nd rings were adjusted in the same manner for .014" end gap.
The oil ring rails were all checked to assure there was at least .015" end gap
lookin good dak.
