Results 1 to 8 of 8
Thread: Parts-Mostly Fox
    1,220
    Parts-Mostly Fox
    *GT40 or Cobra 1/2 inch intake spacer with 1 gasket $10.00
    *1992 T5 trans crossmember $5.00
    *Stock pullies (Crank, WP, Alt) less than 80K miles $5.00
    *Stock T5 shifter with knob Less than 80K miles $5.00
    *NOS 87-93 Radio delete and antenna delete $30.00
    *Cable cover from side of bellhousing $5.00
    *Fox body dead pedal (Came from an 88) $5.00
    *87-89 Steering wheel with cruise $5.00
    *87-89 Fixed steering column covers $5.00
    *87-93 6 piece front lights $10.00
    *Ford Racing spark plug wire seperators New $5.00
    *A9P Computer. Tested. $75.00
    *Exhaust bracket between trans and crossmember Free
    *24560R15 BF Goodrich tires Less than 500 miles $60.00
    *6AN line, exhaust heat wrap, positive and negitive battery cables for side terminal GM New All $5.00
    *Demo Derby builders kit. Steel boat gas can and between 90 and 100 pieces of metal measuring 1 1/2 inches x 4 inches x 1/8th inch thick. I had a bunch of these made when I was building derby cars. $75.00
    *RCS red neck brace $10.00
    *NOS drivers door power window switch. Part # E3SZ-14529-A I bought this for one of my Turbo Coupes or my Mark VII. I can't remember which one. $5.00
    *Stock driveshaft 92 5.0 5spd. Less than 80K miles $10.00
    *Stock 87-93 Hood Nice $50.00
    1,220
    Bump
    1,220
    Couple things added
    Stock 92 intake plaque $5.00
    Ashtray door repair kit. New $10.00
    1,220
    New list-Some stuff is sold
    *6AN line, exhaust heat wrap $5.00
    *Demo Derby builders kit. Steel boat gas can and between 90 and 100 pieces of metal measuring 1 1/2 inches x 4 inches x 1/8th inch thick. I had a bunch of these made when I was building derby cars. Also includes new positive and negative battery cables for side terminal GM $75.00
    1,220
    Computer is sold
    1,220
    Tires and hood are sold. Thanks Dave.
    Also... Thanks to Russ who bought a few things.
    Senior Member 95gts's Avatar
    Sep 2008
    Brownsville
    290
    how much exhaust wrap is there
    95 Mustang gts... Cobra intake,GT40P heads, F-cam, sds efi, 60lb injectors, Garrett turbo 11lb's!!!
    1,220
    Quote Originally Posted by 95gts View Post
    Most of the roll. I only wrapped a couple small sections of the left side header on my Olds where the Z bar passed through.
  1. Fox parts!!!
    By 91gtlmstang in forum Ford Vehicles
    Last Post: 08-02-2013, 03:48 PM
  2. 5.0 fox parts
    By ryan319 in forum Ford Vehicles
    Last Post: 12-07-2008, 09:02 PM
  3. FS:SN95 brake parts,few fox parts too
    Last Post: 12-27-2007, 02:49 PM
  4. Need a few Fox parts
    Last Post: 11-11-2007, 10:35 AM
  5. Various Fox Parts
    Last Post: 06-28-2007, 05:45 PM
