Results 1 to 4 of 4
Thread: Heads
    Senior Member ruger77's Avatar
    Mar 2009
    Greensboro, PA
    133
    Heads
    Looking for good used or new heads for a 1988 5.0? No GT40-P's! Any other makes considered! Current set up is stock block with GT40 upper/lower intakes, BBk longtubes, BBk CAI, BBK pulleys, and Comp Cams XtremeEnergy XE264! Any for sale?
    • 1988 Mustang GT - 5spd. - 12.09@117 Procharger just added! Times???
    • 2005 Dodge Ram Hemi - 13.57@ 100.9mph(75shot)
    • 2006 Eclipse GT - 6spd. - wife's - 14.09@ 97.9mph (CAI only)
    • 2010 Focus SES - wife's - 37.8mpg!
    Senior Member 89 vert's Avatar
    plum
    487
    Why no GT40p's?
    MSD ignition/King Cobra clutch/Polished Cobra upper and lower/Ported GT40p w RR/ 70mm tb/ 24 lb injectors/ pullies/ Mac cold air/ Mac long tubes/ H pipe/ 3:73 gears/ 3g alt/ welded sub frames/ Alum driveshaft/ CC plates/125 shot of juice/custom trunk/suspension goodies.
    FIRST PLACE 87-93 FOX BODY BUCKEYE STANGS SHOW 2010 AT SUMMIT RACING
    283 hp / 320 tq on mustang dyno (all motor)
    Quote Originally Posted by 89 vert View Post
    Why no GT40p's?
    Don't the P's take a different header?
    Mar 2009
    Greensboro, PA
    133
    Why no GT40p's?
    I was told be a couple of experienced Mustang guys that the GT40-P's wont fit my headers!
  1. GT40 3 bar iron heads,NOT P HEADS!
    By 1badnotch in forum Ford Vehicles
    Last Post: 07-05-2014, 03:14 PM
  2. what heads are these?
    By somethingclever in forum Fox-SN95
    Last Post: 04-11-2010, 06:59 PM
  3. heads
    By blkp42e in forum Fox-SN95
    Last Post: 09-20-2007, 04:16 PM
  4. PI heads
    By Mitternacht in forum SN95-New Edge
    Last Post: 08-11-2007, 03:57 PM
  5. 5.0 heads
    By eddmann55 in forum Ford Parts
    Last Post: 06-23-2007, 11:14 PM
