Results 1 to 16 of 16
Thread: Matt's 2005 GTO
Hybrid View
    Brighton Township
    1,665
    Matt's 2005 GTO (Faster than the other black one)
    Car is a 2005 LS2 GTO Automatic, Phantom Black Metallic.
    Current mods are:
    17x8 Black ASA AR1 Wheels
    Built/Vacuum modulated 4L60E trans
    Vigilante 3200 stall
    236/236 .6xx/.6xx 113LSA cam
    Harris Speed Works 90mm nitrous plate kit
    Pacesetter longtube headers
    Catless mids
    Magnaflow catback
    Ported Throttlebody
    Lingenfelter cold air intake
    SJM Linelock
    Car went 11.88@119mph at the end of 2008 before the built trans/stall/cam with just Headers, Lingenfelter intake and a 100 shot of nitrous.
    [ame="http://www.youtube.com/watch?v=8Mzg3CHIxs4"]YouTube- Video from stands of 11.88@119mph Pass[/ame]
    [ame="http://www.youtube.com/watch?v=bhbnlUIf92o"]YouTube- My cammed 2005 Pontiac GTO[/ame]
    Brighton Township
    1,665
    Now on to the 2010 build.
    2009 was a VERY frustrating year, First the built trans blew up the opening weekend of PRP 2009 then we had 2 different cam setups in the car and it did not put down the numbers it should have (12.4 N/A, should have been in the high 11's)... When Ed from VA Speed ran my car on the dyno it only managed 406rwhp through a locked converter N/A, Ed pointed out that there was an airflow problem somewhere.
    So for 2010 I am going to an L92/LS3 top end setup with a custom grind cam for the application.
    Things I will be adding:
    L92 heads milled 0.030 to retain stock compression
    LS3 Intake manifold
    LS3 Injectors
    Custom grind L92 cam
    25% Underdrive pulley
    LS7 Lifters
    Lingenfelter/Walbro high flow fuel pump
    Svede Speed Over the Radiator Cold air intake
    Billet oil catch can
    And Edcmat-l1 will be dyno tuning it in April
    Some parts porn:
    Polar Vortex
    6,031
    Nice! What kind of times/numbers are you looking for?
    Brighton Township
    1,665
    On the new setup I would be happy to see ~450-460rwhp N/A and close to 600 on a 150 shot.
    Just want to see 11's N/A and 10's on spray.
    Dropping heads off at the machine shop tomorrow morning to get milled 0.030
    Mars, PA
    1,696
    Yawn
    Dennis
    2006 GTO
    Gone but not forgotten
    2015 SHO
    Mostly stock
    2014 Cruze
    Living the MPG life
    nice ride/nice upgrades... hope ya can reach your goal, i dont see why you couldnt.. I cant wait to be able to get a ls build going..
    Jun 2007
    2,108
    You still messing around with those slow GTO's?
    Brighton Township
    1,665
    Mostly Lurking demonspeed's Avatar
    Mar 2010
    Seven Fields
    23
    Nice setup! Makes me reconsider my GTO... eh... not really. ;)
    Interesting to see several Lsx people here.
    Brighton Township
    1,665
    Car is running!
    Installed this past weekend:
    Milled 0.030 L92's, LS3 intake, LS3 Injectors, VA Speed custom grind LSR Lobe cam, Summit Underdrive pulley, new LS7 lifters
    PTV was great, we had out doubts because the cam is pretty big for this setup but we had ample room.
    [nomedia="http://www.youtube.com/watch?v=GdlITeJYu4w"]YouTube- 2005 Gto L92/cam idle[/nomedia]
    The car will hit the rollers next month when Ed from VA Speed comes to town to tune it. Numbers will be posted then.
    Car sounds good Matt. Congrats
    Brighton Township
    1,665
    Thanks Ray!
    Idle will smooth out once tuned... Can't wait to see what she does on the rollers at the end of the month.
    Spencerport, NY
    3,762
    very nice....
    still using the same cam as in the OP or a new one?
    2015 Corvette Z06
    - Shark Grey / Kalahari
    Brighton Township
    1,665
    New one that was designed for the heads Bish... This one is high 220's intake/high 230's exhaust, 61x/62x lift on a 114 lsa ground on comps new LSR lobes, very wide duration split, smaller for the big intake runners/valves and bigger for the smaller exhaust flow numbers.
    Brighton Township
    1,665
    Getting closer!
    Brighton Township
    1,665
    Almost ready for the dyno! Need to tighten up some fittings and lines when I get home and swap the catless midpipes on and she is ready. Should have numbers by Wednesday or Thursday.
  1. GTO vs. GT
    By Cam99 in forum The Bar
    Last Post: 03-31-2010, 12:20 PM
  2. modded 05 gto
    By 92306gt in forum Ford Vehicles
    Last Post: 02-09-2009, 11:06 PM
  3. GTO wheels
    Last Post: 02-03-2009, 08:25 PM
  4. Gto Stuff
    Last Post: 10-13-2008, 12:25 PM
  5. 05 6.0L GTO vs 94 Stang GT
    By Slow5.0 in forum Pictures & Videos
    Last Post: 10-13-2006, 04:35 PM
