Results 1 to 20 of 23
Thread: Bigger Injectors
    Senior Member ruger77's Avatar
    Mar 2009
    Greensboro, PA
    133
    Bigger Injectors
    I bought a 1988 Gt and need some advice. The engine has GT40 upper and lower intake, BBK CAI(fender), Trickflow cam(model unknown), BBK longtubes, no cats, underdrives, BBK adj. fuel regulator, roller rockers, 3.90 gears, 5 speed, stock TB & MAF! Injectors are tan, i believe stock. I plan on upgrading heads and adding some NOS! Should I upgrade to 24lb. injectors or higher?
    • 1988 Mustang GT - 5spd. - 12.09@117 Procharger just added! Times???
    • 2005 Dodge Ram Hemi - 13.57@ 100.9mph(75shot)
    • 2006 Eclipse GT - 6spd. - wife's - 14.09@ 97.9mph (CAI only)
    • 2010 Focus SES - wife's - 37.8mpg!
    Your mom cwh19's Avatar
    May 2009
    Greensburg
    1,383
    Quote Originally Posted by ruger77 View Post
    If you do nitrous, TB, MAF, injectors, and fuel pump need to be upgraded.
    15gt
    94gt
    Petersburg,PA. 16669
    816
    you have a stage 1 cam most likely
    If you put heads on you need to upgrade meter,tb and injectors(24's)
    I'd put a GSS 340 pump in it and that wil ltake care of all your fuel needs
    If you are just going to run nitrous just put the gss 340 in. That is the only upgrade needed for nitrous. All of the other parts will help but stock injectors will work just fine. Injectors do not need to be upgraded for nitrous
    88 GT...and some boost
    Mar 2009
    Greensboro, PA
    133
    It has a 255 fuel pump already. I forgot to mention that. Should I go with 24lbs. or is 30lbs. too big?
    Belle Vernon
    1,294
    Its a stage 1 cam and go with the 30lb injectors.
    '89 Mustang GT
    '04.5 Duramax
    Jones Race Car Trailers
    www.jonesrv.com
    816
    I'd go 30's too if you put heads on it
    RRT juice_man_86's Avatar
    Uniontown, PA
    533
    30's are not too big, but 24's would be at there limit or close to it, with heads
    Mar 2009
    Greensboro, PA
    133
    Mike I guess you would know what cam it has!!! I cant wait till PRP opens and I know you are waiting too! Cant wait to hang out up there!
    Belle Vernon
    1,294
    You better get that car down Tims to get the heads ect... before it opens :D
    '89 Mustang GT
    '04.5 Duramax
    www.jonesrv.com
    Mar 2009
    Greensboro, PA
    133
    Mike am I going to see you at PRP?
    Mar 2009
    Greensboro, PA
    133
    I am looking at 30lb. ford racing injectors and I see several types. EV1, EV6 etc. Does anyone know what style a 1988 GT 5.0 takes?
    EV1 are the normal injectors for a fox ... These have the right body and connector for plug and play.
    EV6 are a newer style (faster) injector that bring a lot of benefits, but may not be suitable when you do the "MAF match to injectors" thing typically done with a Fox.
    To add confusion, you can get EV6 injectors with EV1 connectors :D
    Mar 2009
    Greensboro, PA
    133
    Those EV1 are with jetronic connectors right?
    I don't know that term. The only other name I've heard associated with the EV1 connector is Minitimer.
    The "EV" designation is sort of new. When there wasn't EV6's and such, they never used the EV1 designation. Go to Summit and look them up by application ;)
    Belle Vernon
    1,294
    Yeah Ill be at PRP the first day. I hope to see you running the car also. You need the EV1 style injectors for your setup. Some guys like to run the EV6's and then you have to get the adapter. 30lb EV1's are all you need.
    '89 Mustang GT
    '04.5 Duramax
    www.jonesrv.com
    Mar 2009
    Greensboro, PA
    133
    I will be there to see what she does! Think it will be better than the 4x4?
    Mar 2009
    Greensboro, PA
    133
    Is your Capri black with tinted windows?
    Yep!
    Belle Vernon
    1,294
    It should be faster then the truck like I sold it to you. Plus the mustang is NA you sprayed the truck to go that fast.
    '89 Mustang GT
    '04.5 Duramax
    www.jonesrv.com
    Mar 2009
    Greensboro, PA
    133
    Yep!
    Your car is awesome looking! I love that bodystyle!
  1. One of the bigger stang projects
    By ZachTTLM in forum General Tech
    Last Post: 09-01-2011, 10:00 PM
  2. wtb carb 650 maybe lil bigger
    By chuck94 in forum Ford Parts
    Last Post: 06-12-2011, 06:48 PM
  3. WTB:200cc or bigger aluminum heads
    Last Post: 12-20-2010, 06:58 PM
  4. Bigger Pm Box
    By Rodeheaver's in forum Site Announcements, Discussion & Help
    Last Post: 02-09-2008, 10:37 AM
  5. wanted (8)-42# injectors or bigger
    By went9s in forum Ford Parts
    Last Post: 10-10-2007, 07:40 PM
