Thread: question bout installing piston rod bolts
    Hey I was putting together my shortblock this weekend. I over tourqed the rod studs and broke two so I am gonna replace both on each rod. I reserched this and half the people said a machine shop has to re bore after install. So my question is have u installed them without machine shop and have no problems or is it a must .thanks
    If they are stock bolts, you could be fine.
    Senior Member coralcoupe1993's Avatar
    Robinson
    3,842
    You should be fine.
    87 GT
    93 Notch
    60 Country Sedan
    Fairlanes/Galaxies 59-68
    67 Contiental 4 door
    06 Powerstroke
    Thanks guys
  1. piston question i forgot to ask.
    By jasons_98gt in forum SN95-New Edge
    Last Post: 06-08-2011, 12:35 AM
  2. I thought you tightened the rod bolts?
    By map351 in forum Pictures & Videos
    Last Post: 01-23-2010, 11:29 AM
  3. question bout a quad??
    By INSANELY CRAZY in forum The Bar
    Last Post: 01-05-2008, 05:01 PM
  4. question bout heat exchanger an drive shaft?
    By PunisherStang in forum SN95-New Edge
    Last Post: 06-28-2007, 11:06 PM
  5. Replies: 5
    Last Post: 03-13-2007, 11:16 AM
