Results 1 to 6 of 6
Thread: pa c4 grinding!?!
    16psi mplacek's Avatar
    Nov 2008
    Brownsville
    57
    pa c4 grinding!?!
    So I bought a performance automatic c4 super comp off someone a couple months ago and everything was fine.... the other day I noticed a grinding/ whining sound while driving the car and shortly after I went to put the car into gear from neutral to 1st and it made a grinding noise then stalled the car it has done it several times now... not to sure what to do I dunno if it would be converter or tranny. It also whines in neutral sitting still
    Plum
    605
    PA should have a lifetime warranty....
    93 GT, 408
    All Motor.
    Nov 2008
    Brownsville
    57
    They do but its non transferable and I dunno who originaly bought it
    Does it kind of sound like a power steering whine? If so it may be the pump going out.
    Nov 2008
    Brownsville
    57
    Yeah actually it does..... would that cause it to not go in gear also
    Yes it would if there is no pressure the trans wont work. Depending upon the year I have a ton of spare c4 parts. My built one lost a planetary.
  1. flaming river manual rack grinding??
    By Gray 5.0 in forum Fox-SN95
    Last Post: 10-23-2009, 03:19 AM
  2. Slight Grinding noise
    By SonofaBish in forum General Tech
    Last Post: 02-05-2008, 07:54 AM
  3. Grinding noise?
    By turbostang3.8L in forum General Tech
    Last Post: 07-21-2007, 04:12 AM
