What kind of big and little setups do you guys have on your foxes? Size and back spacing of rim/tire size? Dont want to do any mini tubbing or cutting up anything so looking to see what i can fit without doing any cutting.. Car is too nice to cut up![]()
Not sure what the front tire size is, but rims are 15 x 4. Rears are 15 x 8 5.5 b.s. with 275s on them. My set plus an extra set of 15 x 8 4.5 b.s. are for sale.Centers included.:D
i have 15/3 in the front and 15/10 with 6.5 back space with 28 11.50 QTP and they fit great i had too roll the lips in and beat in the wheel well and use a 5/16 spacer
15x5 in the front with 1658015's and 15x8 with 5.5. BS in the rear with what amounts to 27x10x15 Drag radials.
I think the best fit on the rears is a 15x9 with 6" BS, I'd run the 275/60 or new 295/55 (28x10) MT DRs. 15x10s with 6.5" BS/15x8s with 5.5" BS are the most common, but I still say the 9" is the best compromise.
Bob, you mean 15x8??
edit
wrong thread / post
brain fart
15x3.5 165-80-15
15x8 5.5bs 275-60-15 Nittos
you guys running et street radials?
Bob, your pics aint no good working
I am but its minitubbed and 325s :)
Bob is running the bias ply ET Streets.
Without minitubbing or beating on the car, the MT ET Street Radials would be 275/50 (26"), 275/60 (just under 28"), and 295/55 (NEW size like a 28x10").
How fast do you want to go and do you have any limits on sizes?
People have run insane times even in the 7s with the small 275/60 MT DRs.
They work now bob, i think it was just because i was at work..
I stroke everyone about the auto's but reality is I'm a fragged clutch away from the same issue .... $500.00 9" clutches :( I'm not even excited about local racing this year. I will likely be out sooner, but the first competion I'm excited about is the UMTR at QCR in late May ;)
