Results 1 to 3 of 3
Thread: Pinion Angle adjustment?
    up and running
    Jun 2009
    south hills
    418
    how do you set the pinion angle for the rear end. i have a 4 link set up and the rear end is all strange adjustables. any tips would be great
    Mt Pleasant, PA
    4,905
    Quote Originally Posted by Gray 5.0 View Post
    I ASSume by strange adjustables you mean shocks ... they don't matter to pinion angle.
    Do you have adjustable upper control arms? lowers?
    I prefer method #2 (crankshaft pinion angle) as shown here ...
    http://www.baselinesuspensions.com/info/pinionangle.htm
    I checked mine both ways, and in my opinion the driveshaft method would have led me astray. I use a simple digital protractor, set it on my crank pulley and zero it out. Go to the pinion flange and adjust to -3 degrees. At that point, the pinion angle is 3 down t othe crankshaft and the driveline anges have to be right.
  1. Jeg Coughlin Jr. Multiple Angle Run
    By Pure Stock in forum Pictures & Videos
    Last Post: 03-14-2013, 04:54 PM
  2. aod tv cable adjustment
    By PSPstang in forum General Tech
    Last Post: 07-31-2010, 03:11 PM
  3. WTB seat back adjustment
    By fran in forum Ford Parts
    Last Post: 06-14-2010, 10:56 PM
  4. Clutch Adjustment Help
    By Stangman701 in forum SN95-New Edge
    Last Post: 03-09-2007, 01:00 AM
  5. 91 4x4 Silverado 8' Myers power angle plow
    By madmaxin22 in forum Ford Vehicles
    Last Post: 09-27-2006, 08:34 PM
