Results 1 to 6 of 6
Thread: Replacement front rotors for fox's
    Kenne Bell Blown 7-UP 9002stang's Avatar
    Imperial
    278
    I was wondering if anyone had any experience with the slotted/dimpled replacement rotors ie powerslot, factory replacement Brembo or performance plus types. I understand the best options are brembo, wilwood, baer etc with larger sized rotors, and dual piston calipers. For street driving and occasional track duty is it worth getting? The price is generally in the $300 and under range with pads. The stock fox brakes have never really been the greatest I do understand.
    2002 GT- Sold
    2003 F-150 ext cab 5.4l v8 4x4
    1990 7-up vert 346rwhp/414rwtq
    08 Polaris/KTM Outlaw 525 IRS
    Quote Originally Posted by 9002stang View Post
    The fox 10.87" rotors and accompanying calipers were inadequate from the gate. Increasing the swept area i.e., greater diameter will help tremendously to cut speed in one of the heaviest fox platforms (read:convertible.)
    Are you eluding to autocrossing when you mention track duty? If not, many of the tracks including prp offer decent shutdown area. I've personally seen a fox body running near 125 mph in the 1/4 utillizing the stock braking system.
    Repeated stops evoke brake fade quite readily with the stock system. Brake fluid boiling point also contributes to fade and should be changed. The cycling (hot to cold) of the fluid lowers the boiling point.
    If I was going to do it on the cheap, I'd concentrate on the front being it handles the majority of % of braking.
    Mr. 331 N8Miller's Avatar
    Dec 2006
    Kingston, PA, USA
    239
    anytime that you can improve on the stopping in a car, its a good thing. also, the slotted/drilled rotors will desipate the heat/gases better, to increase your stopping. I do know, from research on them, that some of the cheaper drilled rotors have cracked. nothing like dangerous, just small hairline stuff that really would effect much at all.
    1986 GT:331, Edelbrock Vic Jr heads, Jay Allen custom cam, TFS R intake, 30# injectors, 75mm t-body, 80mm PRO-M, AFM Powerpipe, BBK 1 3/4 long tubes, BBK X pipe, 4.10s, 5 lug conversion, 99GT rims/Nitto DRs, PBR brakes, Lakewood 50/50s, Moroso rear drag springs, Sub frames, 2.5" cowl, Saleen spoiler
    Power of a low 12 second car, Traction of a high 14 second car!
    1,171
    thats one plce you don't wanna go cheap on ya get what ya pay for
    I bought a set of slotted rotors from LMM over 2 years ago..and all I can say is they kick ASS...they stop me from 140+ MPH and never warped and I have never had them cut....they work! Fox Mustang's had "push and pray" brakes to begin with
    I run stock drum rear (that ill bet are bairly helping due to the adjusters not working) and the fronts are stock other than the slotted
    buy good brake pads and slotted rotors and call it a day
    Mike
    best of 9.66 at 141 MPH
    http://www.mikeymustang.com
    Imperial
    278
    Quote Originally Posted by mikeymustang View Post
    Mike
    Thanks man!
    I understand that you get what you pay for, and I was just wondering if they would make ANY difference.
    2002 GT- Sold
  1. NIB 2 front rotors
    By 4 eyed mustang in forum Ford Vehicles
    Last Post: 11-27-2011, 09:03 PM
  2. 99-04 Drilled and slotted (used) rotors front
    By dpl133 in forum Ford Vehicles
    Last Post: 05-22-2010, 12:34 PM
  3. Fox body 4 Lug front rotors
    Last Post: 11-28-2009, 11:31 PM
  4. 01 Taurus or Sable front rotors
    By SV1000s in forum Ford Parts
    Last Post: 03-27-2008, 08:36 PM
  5. Replies: 0
    Last Post: 01-12-2008, 04:42 PM
