I am thinking of selling my 349 stroker I just built and go a different route.It is fresh and still on the stand.It has new rings,main,rod and cam bearings
Here is what it consists of:
stock roller block .40 over
Probe SRS flat top pistons
5.4 Probe lightweight I beam rods(not the cheaper CNC rods)
3.4 Scat 9000 crank(NEW)
All balanced 28 oz(have receipt)
Moroso 1/2" tool steel girdle
Melling HV oil pump and ARP oil pump shaft
Ford Motorsport 9 position timing set
Canton 7 qt pan and pickup
Trick flow Stage 3 cam
Profesional Products 28 oz balancer
Arp Head studs
The motor currently has:
Trick Flow heads on it with a Stage 2 port job brand new .600 lift springs and new ARP rocker studs
Trick Flow R intake w/ 1" spacer
I am wanting to keep the heads but if someone wants the entire motor I might sell it that way
The motor is still at my engine builders and can be seen in person.All bearing clearances and end play was check and are all great
Pm if you are SERIOUSLY interested and what you want
I would like to get $1800 out of the complete shortblock(that includes pan,head studs,cam,timing set but no water pump or timing cover unless you have a good timing cover to give me)
I want (if the shortblock sell first):
Trick Flow Track Heat Stage 2 heads,rockers,pushrods $1600
Trick Flow R intake $350
If there is something I forgot let me know
I might consider a trade for an S trim blower for the shortblock.Just let me know what you have
