Results 1 to 10 of 10
Thread: Rear disk brakes on a fox
    Rollin in my 5.0 Shorty429's Avatar
    2,247
    Has anyone switched from drums to disks on here? Was it a PITA? What all would i need to do the switch?
    Thanks in advance!
    Black
    1998 GT- PI swap, 3.73's, off road h pipe, flows & some suspension goodies
    White 1986 GT T-Tops- BBK shorties, RAM clutch/flywheel, Bassani catted x pipe, MSD ignition, MAC cai, LMM lowering springs, adjustable skocks & struts, MGW short throw, DD
    Black 2009 Yamaha YZF-R6- custom levers, -1 front sprocket, Jardine GP-1 exhaust, HIDs, custom undertail, custom black windscreen.
    Chevelle Owner Tony71502's Avatar
    Jun 2008
    Bell Acres
    469
    You're going to need an adjustable proportioning valve to adjust the brake bias for the rear discs. You will also need to bypass/disable the stock valve so it used as just a distribution block.
    I'm pretty positive you will need a different volume master cylinder and booster to accompany it (sn-95), however I"m not sure if the stock master is capable of providing enough fluid to the rear calipers.
    You will need to get different axles unless you go with 4 lug discs.
    1991 Jewel Green Ford Mustang LX ~ 5.0L / 5-Speed
    2011 Torch Red Ford Ranger ~ 2.3L / 5-Speed
    1971 White Chevrolet Chevelle Malibu w/ Blue Stripes ~ 8.2L(502) / 4-Speed
    Nothing clever to say.... jaa55's Avatar
    Sep 2007
    Dayton PA
    3,795
    its not hard...........just expensive like everything else haha
    03 Torch Red Anni. Ed. Cobra
    11 Grabber Blue 5.0, 3D500 spoiler, CS valance, GT premium, interior upgrade package, Brembos, MT-82 and Whipple powered SOLD
    01 cobra: traded
    93 LX Modular 4v swap
    Sean Hyland Motorsport forged rotating assembly, Teksid block, 01 cobra heads, cams and intake SOLD
    2,247
    Quote Originally Posted by Tony71502 View Post
    Sounds like a man who's done it. haha I was planning on going 4 lug because i'm on a budget and can't afford the axles right now. Where would i get the the adjustable proportioning valve? I'm new to all this brake lingo lol
    Black
    Sep 2007
    Dayton PA
    3,795
    summit has them give me a second and ill find a link for one
    01 cobra: traded
    Sep 2007
    Dayton PA
    3,795
    01 cobra: traded
    Sep 2007
    Dayton PA
    3,795
    you need to change your 3 line master cylinder to a 2 line
    if you want to go 5 lug, used sn95 axles are cheap
    01 cobra: traded
    2,247
    I think i'll just save up for some nice 5 lug wheels and convert to 5 lug and upgrade my brakes all at once. Thanks for the info guys
    Black
    That would be your best bet. Get some sn axles, the antimoan brackets and calipers. Summit sells the cables and you can keep your center cable stock. Just dont weld the parking brake ratchet like all the other knuckleheads do. Listen to me and it will be great.
    2,247
    Quote Originally Posted by wick View Post
    haha will do
    Black
  1. Replies: 4
    Last Post: 06-21-2014, 12:03 PM
  2. Fox Rear End, Axles, Brakes
    By NateSVT in forum Ford Vehicles
    Last Post: 07-06-2012, 05:48 PM
  3. Replies: 10
    Last Post: 09-15-2011, 06:08 PM
  4. E-brake with rear disk brakes on a fox
    By Chris00GT in forum Fox-SN95
    Last Post: 09-17-2007, 10:34 PM
  5. 8.8 rear disk complete w 355's for fox
    By lib88stang in forum Ford Vehicles
    Last Post: 05-29-2007, 10:55 PM
